Question about Uniden BC92XLT Handheld Scanner
Uniden scanner says pch loc out and will not scan
Sent it to uniden once and they said nothing was wrong with it but its doing the same thing again. how do I fix?
    President:
  • 2,761 Answers
You didn't mention what the scanner is doing when that display pops up, but here are two possible fixes.
With the scanner powered ON,
- Press HOLD to stop scanning
- Press FUNC
- Press and hold L/O until the scanner beeps twice.
This will clear all locked out channels.
For a COMPLETE reset,
- Turn the scanner power OFF
- Turn the scanner power ON while pressing and holding the 2, 9, and HOLD keys
- After about 3 seconds the display will show CLEAr.
CAUTION: the above will clear/erase all information that you have programmed into the scanner, including frequencies, and reset the scanner to the original factory settings.
I hope this info helps.
Posted on Jan 02, 2010
I can't get my uniden bcd396xt police scanner to talk. it will scan, but not talk
Hi Sue,
No it's not a Police scanner, rather a radio scanner.
I will scan, but not receive transmissions.
Two reasons for this:
1. Do you have any frequencies programmed in the scanner, if not, there's your first reason answered.
2. Do you have frequencies programmed but the channels are locked out? If so, there's reason 2 answered.
To unlock channels, you need to press Mon/Hold key to stop the unit from scanning. Now press mon/Hold key and as you do so, notice if you have frequencies programmed and not just a bunch of zeros showing on your display. If zeros are displayed, example: 000.0000MHz, then you need to program the scanner with your favorite frequencies, and I advise that Police should not be programmed. If you do have frequencies programmed, then using the Mon/Hold keys as stated above, go through each channel and unlock each channel using the L/O key, until the L/O icon on the display goes out.
I Hope I have assisted you with your query.
Cheers,
Peter
Mar 11, 2013 | Radio Communications
I have a uniden bc246t how can i get it to load channels, scan hold nothing stored
Rather than loading frequencies via software, try programming manually, if that's going to be to hard, perhaps getting hold of a copy of the user manual (available from Radioshack or similar store) and it will tell you how in a step by step way.
You must have a list of frequencies in hard copy format to be able to do this, I've never used software to program my scanners, including my Uniden UBCD996T digital scanner, after all, half the fun is programming your favorites manually, so you learn how the scanner works.
I hope this is useful to you.
Cheers,
Peter
Feb 19, 2013 | Uniden BC246T Handheld Scanner
Along with an entry, you sent me an offer to win up to $25,000 instantly if I enter my activation code on www.pch.com/actnow; tell me where I to enter my code!
I wouldn't waste your time. Those things are usually hoaxes. Once you get into the site there's suddenly all these terms and conditions on what they just promised you!
May 08, 2012 | Computers & Internet
I had the batteries out for a while and when i put them back in it won't do anything(can't program). when i push and hold the pri button in the lower right hand corner of keypad "pch loc out" appears...
To reset you BC60XLT:
1. Power the scanner OFF.
2. Press and hold the 2, 9, and MANUAL keys while you power the scanner ON.
Bill B.
Listening in since the 60's
Oct 12, 2010 | Uniden BC60XLT Handheld Scanner
Need user manual for Uniden radio/scanner BC60xlt-1.
Follow the link below to download/print the manual for your scanner. You may or may not be able to hear the services you mentioned using this scanner due to its limited frequency coverage. Many public service agencies now transmit in the 800MHz range, and many have upgraded to trunked and even digital radio systems. I cannot find any reference to PCH LOCK, but an educated guess would be that it means all programmed channels are locked out. If none of the 10 channels contain programmed frequencies, displays will show 000.0000MHz, and all channels will be locked out. Programming a frequency into any channel should override the lockout. On the other hand, the message could indicate that this old scanner is tired and in need of replacement. Here's the link to your manual:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Jan 03, 2010 | Uniden BC60XLT-1 Handheld Scanner
Uniden scanner will not scan
Mine did the same thing. I installed ARC-XT-PRO software from BuTel, deleted all factory programming from the scanner, then downloaded/programmed everything I wanted from RadioReference.com. The BCD396XT and BCD996XT are fantastic scanners, but you have to beat them into submission before they will do what you want them to.
Aug 02, 2009 | Uniden BC244CLT Base Scanner
Lock out problem
In all likelihood all the programming has been deleted, which would default the scanner to this condition. Turn on the power & press the "Manual" button, then check the frequency. Keep doing this to ascertain if all have been deleted. If so, re-program the scanner.
Sep 25, 2008 | Uniden BC72XLT Handheld Scanner
BCT996T Scaanner
Uniden's quick key for system toggles the associated system (or systems, as more than one system can be assigned the same quick key) in and out of the scan.
The systems which have no quick key associated with them will remain in the scan unless you go into the menu and set each of those systems to be disabled from within the menu.
To your description above I would add that if you pressed the quick again, for the system you want, that system would be included back into the scan - each press will alternately exclude it and include it.
So - if you want to be able to exclude the other two systems from the scan by using quick key then set both of those to share a quick key, that key will then toggle those two systems out of the scan leaving enabled the system that you want to scan.
For example - three systems... air , fire , road. Say you wanted to be able to exclude air and road from the scan when you heard some fire action going on... set air system and road system to have same quick key (say '1') and fire system to have no quick key or a different quick key (say '0'). Now '1' will toggle air and road out of and into the scan on each successive press. So now when all three systems are getting scanned and you you want to shut out air and road, press '1' once... and they're excluded. press '1' again and they're included again (that's why i say quick keys 'toggle' the scan inclusion/exclusion).
If you see a message 'Nothing to Scan' ( or somesuch ) it means that you have excluded all systems from the scan - so just re-include one or more systems and the message will clear and you'll be back to scanning stuff.
I hope this makes sense the way i've described it.
I have a Uniden BCT15 myself. My suggestion is based on the way that the BCT15 works.. from memory and without the manual and rig to hand at this time.
Hope this helps anyway.
Cheers,
BB (aka Tequila Sunrise)
Nov 25, 2007 | Uniden BCD996T Base Scanner
Uniden BC92XLT Handheld Scanner Logo
280 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
