Does the engine spin by hand freely? you need to see if you can put a pipe wrench or channel lock pliers on the shaft of the motor and see if it will spin over freely.
Comments:
Jul 28, 2009
- Does it turn over with the starter but not start?
Jul 28, 2009
- It sounds like you are not even getting power to turn the starter over. Does it have a pull rope besides the starter? Have you pulled the starter off or seen if you have power to the starter with a test light? I know you put a new battery in but have you checked to make sure the battery is fully charged and nothing is wrong with the battery?
Jul 28, 2009
- That is fine. check to make sure you have plenty of power to the starter or try using jumper cables from your car to the lawn mower making sure you hook them up right. There is no reason why the engine will not turn over unless you have a electrical problem that you are not getting power to the starter or there is something wrong either with the starter or the battery.
Jul 28, 2009
- Did he hook all the wires up right when he replaced the starter?
Sounds like it is locked up. Could be rust in cyl. or liquid lock from gas, remove the spark pulg and see if it will turn. Try to turn by hand or use a wrinch on the main nut on top. If you suspect rust, remove the spark plug and spray wd 40 in there for a day, try to turn with wrinch back and forth. till you free it up. it may burn a little oil but she should still run. You will need to clean the carb it will be gummed up, no doubt with rust or old gas (old gas turns to varnish in about 3-4 months). if it has sat outside it will rust the cylinder thru the muffler thru the exhaust valve if open, moisture finds away.
Comments:
Jul 28, 2009
- You have a starter soleniod that bolts to the wall, put an old screw driver across the two large terms see if it will turn then. If it does you have a bad switch . your wiring from your key switch goes thru a switch on your brake under the frame then thru a switch under the seat. ck the wire by pass all the switches. use a wire stright from your battery and touch the pos. term on the soleniod. if it turns then now you know one of the switches is bad. try that. get back to me.
Was this helpful?
Yes
No
Popular Solutions for Mtd Arnold Oem - 190 - 784 2
We have just acquired a Rover Ranger ride-on mower. It has the triangular steering bar instead of a...
(More)
We have just acquired a Rover Ranger ride-on mower. It has the triangular steering bar instead of a wheel. It came without an engine though we do have one to put in it .It has SC87 stamped on it but no other identifying marks.It has a few chains etc missing in the engine box and a few unidentified parts from the engine box with it.My question is: is there anywhere that we can get info on bringing it back to life in the with all the right bits in the right places?
I believe i flooded the machine attempting to start it.I cannot find the manual and do not recall...
(More)
I believe i flooded the machine attempting to start it.I cannot find the manual and do not recall which way the choke nob is supposed to be turned
sears craftsman tractor model 917 272 670 it feels like it just about to shut off and then picks up...
(More)
sears craftsman tractor model 917 272 670 it feels like it just about to shut off and then picks up power again lasts apprx.10minutes.
