Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Anonymous Posted on Jul 28, 2009
I have Windows XP SP3. I had a software called WindowBlinds. And after I had uninstalled WindowBlinds, some 25 50MB files were left, and everytime when I try to delete them, I get the message: "Cannot delete. Cannot read from the source file or disk." I already tried a registry cleaner, and it didn't work. I had even tried RegistryBooster, and I have to pay for it. Is there any free registry cleaner that can completely remove those files? Thank you.
A Soveral
Level 3:
President:
  • Master 566 Answers
  • Posted on Jul 28, 2009
A Soveral
Master
Level 3:
President:
Answers
566
Questions
Helped
275856
Points
1995
Download runt the Stardock removal utility zapper:
http://www.stardock.com/files/odnt_zapper.exe
If you don't succed, try the free REVO Uninstaller:
http://www.revouninstaller.com/revo_uninstaller_free_download.html
I was using window xp sp2 on my compaq 972tu now I chnaged the window to xp sp3 , the audio device is showing installed but there is no audio. Wht shoul I do
You are proper uninstall audio driver and reinstall audio driver. because sp2 batch file different and sp3 batch file different. so may be audio batch file not match. If not solved then you reinstall windows and proper install all drivers.
More Technical Support Call and visit.
Pavilion a1410n (ER890AA) PC Desktop: HP s1410n windows XP sp3 slowing down...also runn...
Uninstall SP3. In certain cases improper installation of sp3 has caused the system to slow down.
Iertutil.dll
It might have been caused due to some problem in internet explorer 7(IE7)
Try to uninstall IE7. You can use the following method if it does not show up in add/remove programs.
Reference: http://support.microsoft.com/kb/927177
NOTE:
IF SP3 was installed AFTER IE7, you MUST uninstall SP3 first, uninnstall IE7, then re-install SP3. If SP3 is NOT installed, simply follow the procedure as shown.
Step 1:
Make hidden files and hidden folders visible
Click Start, and then click My Documents.
On the Tools menu, click Folder Options.
Click the View tab.
In the Advanced settings list, under Hidden files and folders, click Show hidden files and folders, and then click OK.
Step 2:
Uninstall Internet Explorer 7
To uninstall Internet Explorer 7, follow these steps:
Click Start, and then click Run.
In the Open box, type %windir%\ie7\spuninst\spuninst.exe, and then click OK.
Follow the wizard instructions to uninstall Internet Explorer 7.
Cannot delete file type files from my computer! Please help!
First, try a registry cleaner. After that, right click on the files and check properties. Uncheck read only.
2helpful
My computer only boots successfully after a forced shutdown.
Is it possible that you have installed winxp twice? You say that you installed XP Pro sp3 was that an upgrade from xp home? if so then you will need to uninstall one or both versions of XP then install only one.. Make sure you backup any important files first though
Problem in office 2007 setup
HI Deb,
You will need to update windows to service pack3 first. Then once completed click "start" and open "control panel" and then "Add Remove programs-software" Scroll through list of installed software and identify all and only the office related components "select" each component individually then click "remove/uninstall" Remove all previous installed office components, starting with the smallest sized file to the largest, once completed restart your machine and try the office install disk again. See below for service pack three download info and links:
Download the service pack manually You can use Windows Update or the Microsoft Download Center to obtain Windows XP SP3 online. Check for updates on Windows Update loadTOCNode(4, 'moreinformation'); To check for updates on Windows Update, follow these steps:
  1. Visit the following Microsoft Web site: http://windowsupdate.microsoft.com (http://windowsupdate.microsoft.com)
  2. Click Express (Recommended).
  3. If your computer is up to date, Windows XP SP3 will be one of the updates that is automatically selected. Click Install. If your computer is not up to date, Windows Update will offer some other updates that you have to install first. Install those, and then repeat steps 1 and 2 to obtain Windows XP SP3.
  4. For Windows XP SP3, review and accept the Microsoft Software License Terms.
Windows XP SP3 will be downloaded to your computer, and the Windows XP Service Pack 3 Setup Wizard will help you install it.
Download the latest Windows XP service pack from the Microsoft Download CenterIf you have problems obtaining the service pack from Windows Update, you can download the stand-alone update package from the Download Center. This page will say that this installation package is intended for IT professionals and developers. However, you can safely download this file. The following file is available for download from the Microsoft Download Center:
Download the Windows XP Service Pack 3 package now. (http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4)
2answers
After uninstall and installing HP 5510 can not fax or scan
There is a utility called Microsoft Fit it that might be able to help uninstall the older version of the HP Photosmart software from your PC. It is pretty strait forward to run.
Once it is done try installing the software again.
Please let me know how it goes.
Thanks!
4answers
Document printing hangs at 99%
same problem. everytime i restarted my pc and deleted the printed files from control panel/printers/lexmark x5150.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
