Question about HP DeskJet F4280 All In One Printer InkJet
How do I fix :Alignment Failed due to the alignment plot in the scanner being skewed
    Scholar:
  • 122 Answers
The alignment page was not placed properly on the scanner. You can follow the instructions here http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01367400&cc=us&lc=en&dlc=en&product=3390949
Try the alignment again it should work. Good Luck
Posted on Jul 28, 2009
My hp photosmart c4780 won't align because is keeps saying that the alignment plot in the scanner is skewed
If you have had paper jam and not replaced the rear paper grey plastic retainer correctly or somehow it has become loosened the paper will twist on entry and the printing will be askew. Sometimes not loading paper. It will then also not align when replacing cartridge. Had this problem, took out the retainer that has two plastic points that should locate in the retaining holes and pushed it back. Paper jam, printouts and alignment was then fine. Took me months to figure out as it was printing, just not very straight
Jan 24, 2012 | Office Equipment & Supplies
I am aligning paper after inserting an ink cartridge. However after printing the alignment sheet and putting it under scanner glass it says "Alignment failed or no alignment paper present" help?
Hi
In order to have a succesfull alignment You need to have
good quility of printing
Replace and the other cartridge or try cleaning it frmo maintance menu
on your printers menu
But you have alwaeys the choice to cancel allingment by pressing cancel button
Pls Vote us to keep us alive
Nov 16, 2010 | HP Officejet 5610 All-In-One InkJet...
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
My alignment is skewed on my hp 4680 scanner
Try turning the alignment page around 180 degrees from the way the direction says. That FINALLY solved my problem! The diagram on the printer cartidge implies the page should go one way, but the illustration on an HP link shows the other direction.
Aug 13, 2010 | HP DeskJet F4280 All In One Printer InkJet
Print head seems to be out of alignment. Lines of print seem skewed and blurry. Edges of pictures are not in alignment.
Run the alignment in the maintenance software. Each new print head must be aligned.
Possibly release and remove the print cartridge and reinsert it. Maybe it is skewed.
Mar 21, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Hp 2210 all in one printer/scanner
after replacing the ink cartridge align the printer. Press alignment cartridge located in the printer properties. After printing the alignment get the paper and put it in the scanner. The computer reads it
May 04, 2009 | HP PSC 2210 All-In-One InkJet Printer
Trying to align heads, 5610 HP all-in-one
This seems to be an issue with the alignment of the printer.
Remove both the cartridges from the printer and clean the cartridge contacts with a soft lightly moist cloth and then re-insert the cartridges. Unplug the USB cable of the all-in-one and then let the all-in-one perform the alignment process and once it prints the alignment page. Once the alignment page prints out, place the alignment page (With the printed side on the scanner glass) and then press the Scan button. the alignment process should complete successfully.
For more information, refer the below hp document.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00442099&cc=us&lc=en&dlc=en&product=441125
Jan 07, 2009 | HP Officejet 5610 All-In-One InkJet...
I changed the black ink cartridge as per instructions and the printer printed an alignment paper which i then placed in the printer for alignment but the alignment failed
the page should be absolutely new.and the scanner glass should be absolutely cleaned.and 1 main thing u replaced your black cartridge.but if your colour cartridge is empty it will not accept the allignment complete thing.it will show allignment failed as the particular colour is missing in your allignment sheet which is required to get the allignment complete.
Nov 23, 2008 | HP Office Equipment & Supplies
Alignment failed notice
Could be one of two things....
1 - you may have bad cartridges...when the machine does an alignment it looks for specific marks on the paper...ie..green check marks before each line etc...if the correct marks are not there you will get an alignment failure...if the green check marks are there etc then you have a different problem...
2- spot sensor on the side of carriage is not working...this is the little blue/green light that comes on during alignment. Its what reads the markings on paper so if the markings are correctly there and you still get this error then the spot sensor needs to be replaced. Simple fix that u can do. We sell the spot sensor for $15
Change cartridge (color first) before doing anything.
Inkworks
866-381-0541
Oct 24, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP DeskJet F4280 All In One Printer InkJet Logo
2,645 people viewed this question
Seeker5211
Seeker5211
