The drum has stopped moving and cannot even be moved manually
  • 29 Answers
Buy $300 transmission and pay a total of around $500-$600 to have it installed or buy a new washer stay away from maytag.
Posted on Jul 28, 2009
2 Suggested Answers
  • 4 Answers
SOURCE: Bosch Classixx 1400 Express - Drum not rotating.
Sounds like teh belt has either broken and come of of drum, or is simply lose. take the back off mchine; if broken buy a new one; if lose loosen motor bolts, press teh motor down until belt is taught and retighten. Check first to see if their is soap on the belt/pully/drum/motor carrying the belt as this could be causing it to slip
Posted on Dec 04, 2011
I have a maytag LSE7806AEE that stopped after filling the washing machine with water. I have tried everything to get it started but it will not respond.
since you can get water going, power is ok. Once water is filled, it should start automatically. Sine the drum is not moving to wash the load, it is down to drum mechanism. BTW if you manually move the knob to spin what happens?
Aug 06, 2013 | Washing Machines
My washer's drum is not moving at all.
a worn out or broken drive belt perhaps?
Check your appliances parts diagram to see what it uses
to connect the motor to the drum.
I didnt find your model online so look here and see if you recognize one of these units.
http://laundry.manualsonline.com/manuals/mfg/ge_appliances/ge_appliances_washer_product_list.html
Mar 15, 2010 | GE Washing Machines
My washer makes loud noise during the spin cycle. I think the drum is off center. How do i fix it?
try moving the cloths around to even the load out my washer does this alot.
Nov 25, 2009 | Washing Machines
Dryer drum won't rotate
if there is no air coming out of your vent on back of dryer then it would be likely your motor has gone out.
Jun 24, 2009 | Dryers
Bad squeak, could not get to stop. . oiled the belt(
If you oiled the belt, it may be slipping and can no longer grab the drum to make it rotate. It should be replaced. Also check the belt tensioner and other rollers as well as the main drive motor. The drive belt pulleys, drum, and other supports should be de-greased before you replace the belt so they don't accidentally get contaminated from any residual oil.
Apr 20, 2009 | Hotpoint Dryers
Thumping sound
Most likely the rear drum support has worn and dropped down.
Remove the drum and replace the rear ball and cup drum support.
Mar 20, 2009 | Frigidaire FEQ1442ES Electric Dryer
My hand brake does work when I pull it up even when I ajust it
slacken cable right off ,then remove the rear brake drums and using a small angle grinder clean the lip that forms on the drum as this will stop you from adjusting the brakes right up when you push the drum back on.next check condition of wheel cylinders and ensure their is no leaks and cylinders move when pushed in and not seized.then using a conventional oil can and not that silly spray junk lubricate the pivots and anything that looks like it should move.Then adjust the automatic adjuster till the brake shoes are just touching the drum when you offer it back up and spin it.Next adjust handbrake cable till you have 3 clicks on it .job done
Feb 01, 2009 | 1988 Mitsubishi Pickup
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Drum wont move
you should take off the bottom panel on the front of the dryer. there is usually 2 screws on the bottom. from there, you will be able to see if the belt is on and if you move the drum with your hand as you look inside, you will see if the belt is moving like it should
Oct 27, 2008 | Hotpoint Dryers
Top loading washer whirlpool
When we move the drum, even with our hand, about 1/2 way through, there is a loud clicking, popping type noise? Sounds like a train is coming through the house before it stops the cycle?
Dec 20, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
