SOURCE: I have a 2008 Honda with a 190 HP V-Tec 4 cylinder
it should say on your engine oil cap or owner manual....i believe its 5w20
SOURCE: 1994 sporster 883 rocker box bolt torque specs and order
unless you have the motor out its near if not impossible to get a torque wrench on the bolts so what most do use blue loctite on your bolts and draw all bolts down evenly till you make metal to metal [cover to rocker] then maybe 1/8 turn more the key is even torque
SOURCE: Sea doo jet ski won't get full throttle. It idles
I am not sure of the model that you have,so its a bit hard to help.If you have a seadoo and you want great help,I would go to seadooforum.Its the best site with really good,and also total knowledge of all things Seadoo.I have one also.The help is unsurpassed.I have a seadoo also.Hope this helps you
SOURCE: Once I install the chain
Hello manley. your cover may be warped but before you replace it try reducing the tension a wee bit so that you can lift the chain, in the middle of the bar, so that the teeth are above the bar.
You may just be tensioning the chain too muc. J.
SOURCE: 2002 gti sea doo wont turn over on the first try
if you have one of the kill cords that is round and it snaps onto a round button that has a silver dot in the center that when the kill lanyard is snapped into place makes a connection to the silver part inside of the kill lanyard itself. most the time its because it is still verifying that it is the right key. they are programed to match you CDI box/ignition module of your ski. this prevents theft. if you clean both the key and the button the key connects to with some rubbing alcohol to insure a good clean connection will most likely solve the problem. when you put the key on the ski you should hear a beep then wait 5 to 10 seconds before hitting the start stop button . that gives the ski time to recognize the key is in fact the correct key to the ski.. hope this helps
