Question about Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet - 091
Eljer pressure assist handle will not move. If water valve is on, water will conitnuously run with no shut off
  • 117 Answers
If you take the lid off the toilet there is a cartridge in the middle of the tank. if you take the handle mechanism off the toilet and get some plyers you can take the cartridge out of the tank by twisting it out. make sure the water is off and that you have pressed it down ( the part that stick out of the middle of the cartridge)to relieve the pressure. it should come right out and take it to a local plumbing supply shop and they should be able to get you a replacement part for it.
Posted on Jul 28, 2009
Trickle leak refill 1-2 minutes city water 40 PSI
the flapper valve is a common piece to obtain and easy enough to replace..
Aug 02, 2010 | Eljer Aqua-Saver 12" Two-Piece...
Tip
Backwashing A Sand Filter with A Push/Pull Slide Valve or Multiport Valve
Lots of people are first time pool owners and pool professionals forget to teach these "newbies" about the simplest aspects of pool ownership.
One of the biggest questions we receive from new homeowners is "How do I go about backwashing my sand filter exactly?"
It doesn't matter if you have a Hayward, Pentair, Jandy, Sta-Rite or any other number of Sand Filters on the market they all utilize the same basic valves for backwashing; a push/pull slide valve or a multiport valve.
To backwash with a multiport valve:
1) Shut off pump motor.
2) Press down on valve handle, rotate valve from FILTER to BACKWASH position.
3) Roll out any backwash hose or open any waste line valves.
4) Open air bleeder assembly on filter, and turn pump on.
5) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
6) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
7) Shut off pump motor and move multiport valve handle to RINSE position. Run on rinse for 15 - 25 seconds.
8) Shut off pump motor and move multiport valve handle to FILTER position.
9) Turn pump back on and note lower pressure.
10) Roll up backwash hose so the dogs use it as a chew toy.
To Backwash a sand filter with a slide valve:
1) Shut off pump motor, roll out backwash hose.
2) Twist to unlock plunger T-handle, push or pull(depending on manufaturer) the plunger 2" - 3".
3) Open air bleeder assembly on filter, and turn pump on.
4) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
5) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
6) Shut off pump motor and push T-handle back down into locked position.
7) Turn pump back on and note lower pressure.
8) Roll up backwash hose.
Now you are a backwash Guru!
More tips and tricks are available form The Ugly Pool Guy, www.WeFixUglyPools.com
on Dec 14, 2010 | Pool & Spa
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Jun 01, 2010 | Eljer Home
The water wont fill back up after you flush it
MAKE SURE THAT THE HANDLE OR CHAIN IS NOT GETTING HUNG UP ON SOMETHING INSIDE OF THE TANK,WATER WON'T FLOW UNLESS THE FLOAT DROPS DOWN
Apr 05, 2010 | Eljer Walford Two-Piece Pressure-Assist...
Always have to hold handle to get it to flush
lift the lid,and look, flush, the rubber valve that opens when lever is is pulled should float, so either its very loose or broken and needs to be replaced.plz rate-bozcro
Sep 10, 2009 | Eljer Aqua-Saver 12" Two-Piece...
I have a Eljer 150-403 and the toliet will not flush, although the handle is able to be moved down
Remove the tank lid and set it aside. Inside, you should see where tha handle passes into the tank. There should be an arm running along the inside of the tank that raises when the handle is pushed down. Attached to the end of the arm is a chain that goes down into the water and attaches to the flapper valve. Now that you have identified all of these parts, push down on the toilet flush valve, and you should be able to identify where the toilet is broken. It is most likely he flapper or the chain.
Shut the water off behind the toilet, at the wall. Slowly stick your hand into the tank, and raise the flapper. (Don't worry, this is clean water).
Let the water drain through the toilet, and make your repair. All oarts necessary are available at any hardware store. Take your old part with you.
Best regards, --W/D--
Aug 11, 2009 | Home
No water at flush
sound like the water shut-off needs to be replaced.
if you turn on/off the shut-off, the tank get enough water to flush, then you get less water every time you use the toilet. that is the shut-off valve problem.
you may able to to just change the rubber seal.
I have not found change the seal will last as long as a new valve. better off, just change one.
Feb 11, 2009 | Eljer Aqua-Saver 12" Two-Piece...
The water continue to run for a long time
You are probably going to have to replace the fill valve.
There is a chance that adjusting it may work, but it has most likely become worn and partially clogged with hard watrer deposits, dirt, etc.
This will cause it to fill slower, and cause the fill level valve to close slower resulting in higher water level. Eventually it would simply overflow the flush valve tube.
Try adjusting the fill level, but plan on the likelyhood of replacing the fill valve.
Jan 21, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Kohler shower facuet pressure balancing problem?
ever since the pressure balancing regulations came out for shower valves, they have went from simple to very complicated devices. sounds as if some foreign material caused the valve to stop working. that valve is quit difficult to reassemble correctly because there is only one way it works and can be assemmbled many ways that do not work concerning alignment of the ports. if you dissassemble it and check that all the moving parts are functioning in the balancing cartridge you can then look closely at the alignment of the ports on the cartridge that the handle is connected to. understanding how the port align as the handle is turned should assist you in assembling it correctly......hope this helps.
Jan 20, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Toilet doen't stop flushing
Sounds like the flapper is stuck in the open position.
They sometimes get hung on the flush tube or the chain hanging from the handle.
Is the water level overflowing the tube?
If so, try adjusting the level down, you may need a new fill valve if that doesnt work.
Nov 18, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet - 091 Logo
160 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
