Question about Creative Labs ZEN SLEEK MP3 Player
Zen sleek photo not recognized by my computer
Then Zen Sleek Photo player reads docked but the computer is not recognizing the player as being attached so I can proceed from there. What are my options?
  • 4,402 Answers
Re: zen sleek photo not recognized by my computer
Posted on Dec 06, 2007
0 characters
3 Points
My creative software for Zen Sleek Photo won't load on Vista
Vista by default will support the Zen Sleek Photo as an MTP device, which means that Windows Media Player will recognize it as well as Explorer.
You can use WMP to sync music to it, and Explorer to drag/drop photos to it.
Apr 01, 2009 | Creative Labs ZEN SLEEK MP3 Player
Comp will not recognize Zen Sleek Photo, it says it malfunctioned
I had the same problem. I took all my router ports off and connected just my creative vision and it worked. System was over loaded.
Feb 22, 2009 | Creative Labs ZEN SLEEK MP3 Player
My zen photo sleek is stuck in recovery mode
I had this same problem and almost threw out the Zen. You need to download the Zen Sleek Photo firmware upgrade software from Creative (
  1. The firmware updater needs to run in XP SP2 or SP3. It apparently won't run on Vista.
  2. The trick to getting the Zen recognized by the firmware update software is to make sure you uninstall both WMP11 as well as the WMP11 Runtime. Those two things are listed separately in Add/Remove programs. BOTH must be uninstalled before the firmware updater will recognize your Zen.
Now I'm back to using my Zen. It's all good.
Nov 26, 2008 | Creative Labs ZEN SLEEK MP3 Player
Sep 03, 2008 | Creative Labs Zen Sleek Photo MP3 Player
Getting out of recovery mode
The recovery tool mentioned above is not designed for the sleek photo. You need to download the firmware for the sleek photo from creative's site. Now we need to get your player recognized to get the firmware loaded. If you have Windows Media Player 11, it needs to be removed. Also remove WMP runtime. After that, restart the pc and your player should be recognized. You can then double click on the firmware program to run it. It might say something like, this firmaware is already you want to reload it? Click yes to reload.
I had the same problem with my sleek photo. Once I got rid of WMP and the runtime everything worked like a charm.
Jul 02, 2008 | Creative Labs ZEN SLEEK MP3 Player
My creative zen sleek photo mp3 player is not being read by my computer.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Jun 03, 2008 | Creative Labs ZEN SLEEK MP3 Player
Computer stopped recognizing USB cord from Zen sleek photo
The first problem is probably a software incompatibility between Creative's software and Windows Media Player version 11. The second problem is possibly a need to replace the battery. 3rd party batteries are about 20 dollars now.
May 28, 2008 | Creative Labs Zen Sleek Photo MP3 Player
Help me
Have you tried inserting a paperclip into the small hole to the right of the port?
Apr 26, 2008 | Creative Labs Zen Sleek Photo MP3 Player
Creative zen sleek photo not recognized by win xp
I got my Creative Zen Sleek Photo from a friend and everything I did wouldn't let Windows recognize it, but then I got it to work almost magically.
1. Make sure you have the proper drivers installed for it that come with the CD. If you don't have the CD, you can download the ISO here.
2. Reboot. When it comes back up, plug the cable into your computer, then into your Sleek. The software should sync up. For some reason, my Zen wasn't being recognized from the usb port on my computer tower, but I plugged it into my monitor's USB port and then it worked. Try that, if none of that works, then it may be a problem with your computer not knowing which driver to assign to your Zen, and if so, try the steps below.
1. Plug your Sleek to your computer.
2. Open up Windows' Device manager (right-click on "My Computer" and select "Properties". Go to the "Hardware" tab, then click "Device Manager").
3. Locate the entry for "Creative Zen Sleek" in your device list. It should appear either under "Sound, video, and game controllers" or under "USB Devices". Once you locate the entry, uninstall it.
4. Unplug your Sleek and wait a few seconds.
5. Plug your Sleek back in and allow the "new Hardware Wizard" to identify and install the drivers for it.
Mar 01, 2008 | Creative Labs ZEN SLEEK MP3 Player
How to bring a Creative Zen Sleek Photo to life
If you can, the best test is to try your player with another PC,
Feb 04, 2008 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN SLEEK MP3 Player Logo
109 people viewed this question
Top Creative Labs MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Creative Labs MP3 and Digital Media Player Expert? Answer questions, earn points and help others
