Question about Garden
Mower has sat for about 3 years, so we replaced the battery, and put a new starter also. It will not even turn over. Any suggestions?
  • stevecook2 Jul 28, 2009
    even if the motor does not turn at all?
    Scholar:
  • 70 Answers
Now drain and replace the fluids, clean the air filter, put in a new spark plug, add some stabil fuel additive and good premium grade gas.
Give it a while and continue cranking it periodically and it should start
Posted on Jul 28, 2009
  • jazzy6er Jul 28, 2009
    Sure,..
    I presumed it was your mower and it was in running order when you stored it. If it was damaged as the reason you stored it it's going to still be damaged now.
    See storing a operational vehicle or mower doesn't break them nor create any hard fault from inactivity either. But after 3 years it's not likely too start right up.
    Thus is why I stated draining all the gummed fluids and insert a new spark plug, good fuel and fuel additive.
    That along with lubing the blade shaft and double check all your electrical connections. Or cite the mower as a loss and discard it if not seeing it's worth putting in the time and parts to get it running.
I just bought a two year old Huskee riding lawnmower yesterday and it was working fine through test drive and even got through 2/3s of the lawn before I had to gas 'er up. After I put gas in it, it won't...
Checklist for troubleshooting:
1. If all safety switches are engaged (blades disengaged, machine in neutral, etc) and turning the key results in either a "click" sound or no sound, test the battery with a voltage tester. It should be 12v to 13v. If not, you may need to charge it or jump it.
2. If the battery has 12v, and you get a "click" or no sound on turning the key, the starter solenoid is likely the culprit. The contacts wear out from arcing over time and there is no repair but replacing the part. The solenoid can be tested by crossing the two terminals and bypassing it with a jumper cable. If the engine turns over when doing this, the solenoid is bad. If it does not, then the starter itself is bad.
3. If the starter is verified as good, and the battery has sufficient charge, and the solenoid is replaced, and the mower still will not turn over when turning the key, then there is likely a safety switch not being made that you will have to hunt for. Generally these are brake switches, seat switches, blade PTO switches, neutral switches, etc.
Oct 08, 2013 | Garden
My mechanic has just put a new starter motor on my car, it's been sat there for a while, and even with the new starter, the engine won't turn over, please help. Cheers
What is the battery amperage? It is possible that the starter is defective as well even though it is new. If you dont have enough power in the battery it will not turn over. Could be a starter solenoid as well depending on the make model...
Jun 07, 2012 | Cars & Trucks
HELP with my problem to my Question and added details
A good hot battery shoulde do it. Have you had any problems with the security system? That's all that should keep it from starting now. Have you put a socket on the crank bolt to make sure the engine is not seized and turns freely?
Good luck.
Apr 29, 2012 | 2002 Saturn L-Series
Cub Cadet ZTR will not start
Is the blade engagement off? If that is ok, does the solenoid even click when you put the key to start position? If the solenoid doesn't even click check the battery connections and make sure they are good and clean. If the connections are good, are you sure the new battery is fully charged. If the battery sat around for a long time in the store it could need charged. If all that is good and then you don't get the starter solenoid to click when you put the key in start position, then it is either the seat switch, parking brake switch, handle switches, or mower engage switch keeping it from starting. If all that is ok maybe you have a bad starter solenoid. Please rate my answer so I am rewarded points for it.
Jan 30, 2012 | Cub Cadet Garden
The starter won't completely turn over even though
Sometimes on the Briggs and Kohler engines, the compression release fails to operate at the proper time or is malfunctioning. A remedy for this is to remove the valve cover(s) and adjust the OH valves per the manufacturers specifications. This enables much easier starting, produces less wear and tear on the starter and may allow your new battery to completely turn that engine over. Out of adjustment valves mimic a weak or failing battery quite well and the engine hangs up on the compression stroke because the compression release system is not working properly. Adjust those darn valves.
May 15, 2011 | Toro Titan ZX5450 (54") 25HP Zero Turning...
Mower sat over the winter. Turn key and nothing
Neither ... charge the battery first. New doesnt necessarily mean fully charged.
Charge it with a properly sized charger for 24 hours then check with a volt ohm meter.
May 01, 2010 | Garden
Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
Mar 03, 2010 | Garden
I have a B&S 16hp electric-start engine. Battery was dying for long time, finally replaced. Can't seem to get it to even turn over now. Checked battery- good. Even assumed I was wrong and new...
i would check the solenoid first if that doesn't work check starter also what you can do is turn the key on & run jumpers from car or another battery ground on engine block of the mower & take the positive & touch the bolt that the positive wire goes to on starter it will cause a spark but if starter turns over & starts then it the solenoid
Jul 04, 2009 | Garden
New Battery, Have lights, Does not turn over
bang the side of the starter with a hammer (dead blow) and hold the start button. sounds like the starter solenoid is frozen. if not check the relay, and the switch, you can check the switch by doing a continuity test on it. good luck ill check back...
May 02, 2009 | 1995 Suzuki LS 650 Savage
Have a Mitsubishi starter for a small 3 cylinder (Toro Mower)
Removed starter and tested with new battery and jumper cables...starter worked fine. Replaced battery and cleaned cable attachments...unit started as usual.
When starter throws this would indicate that the interconnect circuits are intact..the engine still would not turn...that leaves the battery, the cable, or a siezed engine. The engine flywheel turned easily...no siezure. That left only the battery and cable. Battery was 3 years old...cable was corroded...bad combination. Battery was replace and corrosion removed from the cable terminals...started first crank.
Apr 12, 2009 | Diesel Garden
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
