Question about Refrigerators
Model 2351 will not get cold, it has propane and it also has electircity although it will not get cold, is the brain out of order
    Problem Solver:
  • 15 Answers
Check with Dometic. I had that problem and it turns out there was a recall so I got it fixed for free.
Posted on Jul 28, 2009
How to disassemble mixmaster heritage series model 2351
try the following sites
www.eserviceinfo.com/equipment_type/model###
www.freeproductmanual.com/manufactures_name/model###
www.info.com/manuals
www.s-manuals.com/manufactures_name/model###
at the browser type the following information
sunbeam disassemble procedures for make/model ###
you could look at www.youtube.com/disassembling mixmaster model 2351
Mar 31, 2015 | Sunbeam Food Mixers
I have a full propane gas cylinder for my grill in my garage. It is very cold in the garage and I'm getting a propane smell. Does the cold effect this or is there probably another problem?
We live and work in South Florida so I'm assuming what we use "very cold" to describe (below 70) is different from what you're referring to. An LP cylinder is full of very cold liquid propane. Heat (and pressure which causes heat) causes the liquid to vaporize and the vaporized liquid propane is what we burn as fuel. I have experience with some building codes far north of here which have a lot of rules for safety features affecting the use of LP fuel because the fear of reconstituting vaporization into a flammable liquid could cause serious environmental damage.
In the heat, it is common for the tank to release some vaporized gas when the pressure becomes too great which is why all LP techs will advise never leave a cylinder in an enclosed area -- the tank safety features do release vaporized propane in order to release pressure...but this is in hot climates.
In a (very!) cold area the only problem I can think of is slow gas pressurization but we have clients who have used common LP cylinders in zero-degree weather without trouble so I really doubt that.
Make sure the tank is not connected to anything. A damaged o-ring can cause a leak but the cylinder just sitting on the floor by itself should not release anything unless it gets heated beyond the available pressure.
Jan 08, 2015 | Grilling
Meri phone memory full show kr raha hai..but there is no data ,how can format phone memory..plz say something
Type in *#7370# in the main menu, means in the same way you type in numbers before dialing. It will ask you for the default security code, and then the phone will restart itself. Please note that all data saved on your phone will be completely wiped out including Contacts, Sms, etc..
"????? ???? ???, *#7370# ???? ???? ", ????? ?? ???? ?? ???????? ??? ???? ????? ?????? ??. ?? ?? ???????? ??????? ??? ?? ??? ?????, ?? ??? ??? ?? ???? ???? ?????. ????? ????? ??? ?? ??? ???? ??? ?? ????? ?? ???? ?? ???? ??? ?? ??????, ?????? ??? ???? ?????? ?????." (I can't guarantee the translation, it's only google translation,)
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 01, 2011 | Nokia 6120 classic Cellular Phone
Whirlpool side by side Fridge Freezer S20BRBB20
Your fridge is simply not defrosting itself or moving air off the freezer coil. Try defrosting it and make sure the fan is operating. If the brains have been replaced already i do not think you should have to deal with them again unless consumer reports suggest otherwise.
Apr 30, 2010 | Whirlpool GC5NHAXSQ
Refrigerator temperature can't be set to cold - sensor light shows 9C and keeps on beeping. Samsung model RB1855SL
I had this exact problem with my 4 yr old Samsung RB1855SL refrigerator. BTW, the temperature display doesn’t display higher than 9C, even when its warmer inside. The fan wasn’t turning on to circulate the cold air, although the cooling coils were still cooling. There was no excess ice build-up. The freezer was working fine.
I thought perhaps the fan was toast or the temperature sensor. Then I noticed the interior fridge light was not turning off when closing the door (but the freezer light was). BINGO—thig light switch was the problem. A small piece on the inside of the fridge side of the switch was broken. When the door was closed, the broken switch didn’t let the fridge know that the door was in fact closed, causing the door alarm to keep beeping. This must shut the fan down in order to save energy when regularly opening the door.
DIY fix: I removed the switch (until I could get a replacement) which is located to the left of the lower door hinge (right hand side). Gently, with a flat nose screw driver, I pried it out.
The light no longer turned on when opening either door but that was a small price to pay compared to the incessant beeping and rotten food. The part can’t be very expensive and I can replace it myself. The local appliance repair shop will order it for me.
No expensive “internal brain” needed to be replaced or an expensive repairman needed to be called. Good luck!
Aug 17, 2008 | Samsung Heating & Cooling
Need to buy a new brain
I have a factory Clarion Brain unit for the Clarion VRX935VD after my head unit/monitor was stolen from my car 2 years ago. It's been sitting in a drawer in my room on good working order, still have the wiring harness too, although 2 wires have been cut from where they cut it. Interested give me a call 1-234-567-1724 i live in Ohio. I will sell as i have NO USE for it whatsoever and haven't for years, just too lazy to put it up on ebay or anything like that.
Apr 08, 2008 | Clarion VRX935VD Car DVD Player
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
