Condensor won't stay on
Cools for a little while than condensor shuts off and it stops cooling
    Problem Solver:
  • 15 Answers
Compressor is overheating. You need to make sure your indoor and outdoor coils are clean. Sometimes it just needs a vacuum job. If you hose the outside coils, be sure to do it from the inside out. Hosing from the outside will just pack the dirt in farther.
Posted on Jul 28, 2009
Refrigerator not cooling evaporator fan running vent does not seem to be stopped up but very little air blowing into fridge
  • You may simply have a dirty condensor as that will cut down the coolness in a refrigerator
Aug 18, 2015 | Refrigerators
Air runs until car runs a distance and engine is shut down. when restart air is not cool?
Well of course not. When you shut the car down, all water circulation stops so engine heat goes way up. This means the radiator gets hot too, and therefore so does the AC condensor. It takes time for all these things to cool back down when you start it back up.
Jul 14, 2015 | Cars & Trucks
Condensor Fan won't stay running
Check capacitor if its good its the motor
Aug 30, 2012 | Gibson Heating & Cooling
I have a new ptac that won't cool, why?
The condeser fan blade is broken. I work at a place where 75% of these units have cond. fan broken in same place.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/glenn_a4cc4202f1895fe2
Mar 22, 2012 | Amana PTH123B25AJ Heat Pump Air...
My Window unit cools real well in the morning. The air flow from the ac is 50 degrees, then by noon the temperature is 80 degrees and then it won't cool again. I am trying to cool an 8 x 35 ft....
When was the last time you cleaned the evaportor coil and condensor coil???? When its cool outside the condensor if its plugged with dirty can mantain the right condensor Head Pressure by useing the cool outside air when it has to run with 80 to 100 degree air it can't get the head pressure with in range to cool the freon. I would clean the condensor coil.......
Jun 19, 2011 | Friedrich ZStar ZQ10A Air Conditioner
Hi, my cooling fan on my 1992 corola stays on all the time with the key on. Any help? Thanks
A 1992 Toyota Corolla is equipped with 2 cooling fans. One is called the radiator cooling fan and the other is called the A/C condensor fan. They SHOULD BOTH be on anytime the key is on if you have your climate controls set to A/C or DEFROST.
If your climate controls are set on HEAT or OFF, then I would check for a stuck cooling fan relay. Again, there are two - one for the radiator fan and one for the condensor fan. Unplug the relay to shut the fan off. The relays can usually be swapped to see if the problem is actually the relay or some other problem in the circuit.
Dec 01, 2010 | 1992 Toyota Corolla
Condenser shuts down after a couple of hours.
check capacitors, make sure the condensor coil is clean. sounds like the compressor is overheating. is the condensor fan motor still turning when it stops cooling. if not check low voltage wires to condensor, furnace and t-stat
Aug 19, 2009 | Amana Haier AP125HD Air Conditioner
Air won't cool when the car is stopped on a 2004 chevy cavalier. car temp is normal
make sure electric coolant fan is running.if not check or replace fan relay.the coolant fan has to be running to cool down refrigerant in condensor.so refrigerant in condensor is cooled back down to high pressure liquid so it can go to evaporator.see ifcoolant fan not working.the AC is not going to cool.when you driving the condensor is cooling down from moving air when car is going.when you come to a stop.cooling fan suppose to be on so condensor gased can be cooled down.
Jul 10, 2009 | 2004 Chevrolet Cavalier
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
KBFA20ERSS- Fridge stopped staying cool; thermostat doesn't work
Hi, if you can find the input of cool air there a slider to shut it make little way to in cool air to keep cool down.
If there a possible thermostat make it lesser so that thew thermostat will on and off.
Jan 17, 2008 | KitchenAid Architect KBFA20ERSS Stainless...
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
