Question about Gateway FPD2275W LCD Monitor
FPD2275W No PC or On Screen Menu Display
Same problem as others, I get the Gateway Logo on power on & the VGA plug graphic then the screen goes black with no PC screen or on screen menu displayed. I did unplug for five minutes and plug back in but the problem remained.
  • 11,361 Answers
Bad caps, be REAL CAREFUL when take the bezel out, you can easily damage the small ribbon cable attached to the front bezel.
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 08, 2010
My monitor comes on but I have no picture. I tried it on both my computers and still cannot get a video connection. I contacted the store where we purchased it and they do not work on monitors and...
First step is to test and see if it's your monitor or PC that is giving the problem. Plug the screen to a laptop and switch on presentation mode. If nothing shows up, try replacing your monitor (VGA) cable as you mentioned that the gateway logo still shows when you power on, indicating that the monitor somewhat works. The cable looks like this:
If monitor works on the other PC/laptop, proceed to check the video card of existing PC. Update driver and remount the graphic card to see if it helps.
Mar 07, 2011 | Gateway FPD2275W LCD Monitor
I have a gateway FDP2275W desktop monitor. the monitor will power up and display the Gateway logo in the middle of the screen, then goes black. The monitor is still getting a signal from the computer as...
This is a common problem with many LCD monitors. The
printed circuit board that provides a stable voltage for the monitor to operate
from starts to fail. The PCB can be replaced, when/if they are available, or repaired
in most cases at a much lower cost. for more information on this email me at
Sprint6@zoominternet.net
Dec 26, 2010 | Gateway FPD2275W LCD Monitor
Monitor goes blank.
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Mar 30, 2010 | Gateway FPD2275W LCD Monitor
Computer loads windows xp then goes black and does nothing else
This problem occurs because of display driver or resolution issue.
For that when you power up the computer press F8 key before you see windows logo .
then you can see safe and other menu enter in enable vga mode then go to start ->control panel ->display ->settings.
Change screen resolution to 1024*768 then apply and ok.
If sill not able top see display in normal mode then enter in safe mode and uninstall graphic driver then restart computer then install graphic driver again.
Also Reattach all connection to harddrive because some times harddrive is not recognized properly in bios .
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Dell Dimension 8300 PC Desktop
Fpd2275w monitor problem
Have you unplugged the power cord for 2 min. Try that, there are problems with these "locking" and unplugging sort of "reboots" them.
Jun 01, 2009 | Gateway FPD2275W LCD Monitor
Gateway 22" flatscreen monitor won't display after startup
Monitor has blown capacitors internally on the power board I can fix these let me know what you would like to do.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
Gateway FPD1975W TFT LCD Monitor Need to Resize Screen
Did you try changing your display resolution in your computer display properties ?
Right click anywhere on your screen backdrop, click on properties, go to settings then pick the resolution that fits your screen the best.
Aug 20, 2008 | Gateway FPD2275W LCD Monitor
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Monitor not receiving a signal
I have these monitors, didn't you get another cable in the pack which has a vga plug on the end? I have had trouble with those converters, try a DVI to VGA cable
Jan 15, 2008 | Gateway FPD2275W LCD Monitor
Monitor Goes Black
Try to start in safe mode and check if you can change some of the video settings (resolution, refresh rate, etc). Maybe one of these settings is such that the monitor cannot handle properly. To get into Safe Mode, press F8 as soon as you see the Gateway logo on the screen while booting the PC.
Aug 08, 2007 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
235 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
