Question about RCA D52W15 TV
D52w15 comes on then shuts off
Turned tv on its a d52w15 got picture and sound then popped and crackled a couple times then shut down on light blinking 1 then 5
    Champion:
  • 230 Answers
Hi, thank you for visit fix ya.
This is a common problem on this kind tv.
Replace capacitors on power supply.
22000 uf 16V and 220uf 16 V; upgrade to 35V.
For parts, go to:
http://www.encompassparts.com/
Any question I will be here.
Thank you
Posted on Jul 28, 2009
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
My rca d52w17B rear projection screen tv is shutting itself down.
The main reason electronics go haywire is their dirty. You may want to break out the shop vac or the hose on a house vac and a soft paint brush or tooth brush and clean off the bulbs and misc items inside your television. It sounds like it's overheating due to dust on the motherboard. Good luck.
Mar 21, 2017 | Televison & Video
First of all, sorry for the mix up on model the model #. I was viewing a problem regarding LG LCD TVs and found your link. My problem is with an LG 42LGX LCD HDTV. It has worked fine without any issues...
welcome to fixya and thank you choosing my service..
OK,that is the most and common problem of all LCD TV...
Usually dim and totally have no back-light is cause of bad inverter board.One of the inverter board is shorted that cause dim light and crackling sounds..
This are the sample images of inverter board.
to make sure that the problem is on the inverter board kindly try to disconnect/unplug it from your TV and power ON then observe if the crackling sounds remain or not..If the crackling sounds gone replaced the inverter board..Also I need to how many inverter board you have? if 2 or more disconnect it one by one to determine if where is the specific faulty inverter board..
Example:
I disconnect #1 inverter still have crackling sounds..next disconnect #2 inverter and reconnect the #1 inverter until you found the faulty one..Note when you doing this make it sure you power off the TV before you unplug or disconnect inverter board because its high voltage..
I need the picture your TV screen..just send it to chesterpendilton@yahoo.com
Regards.
Chester
Jan 20, 2012 | LG 42LC2D 42 in. LCD HDTV
Heard a pop, tv went off, then doesnt come back on
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 23, 2010 | Hitachi 50VF820 Projection TV
Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
May 15, 2009 | Mitsubishi WD-57732 Projection Television
My tv not turn on
you will need to replace the flyback number 259296 and CP150 you can get the parts at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Mar 13, 2009 | RCA D52W19 52" Rear Projection Television
Have a RCA D52W15 w/ ITC222 board. TV will turn on and stay on for about 20mins and then it will shut off. I have been trying to play an Xbox hooked up through component cables. I even tried not connecting...
Take a good look at the power/deflection board. The one on the left as you are looking the back. You will find 2 ribbon cables that connect the power/deflection board to the small signal board (the one on the right). Look at the connector that the ribbon cables plug into. If they are black in color that is good. If they are white, that is bad. These connectors do cause intermittant power problems ( or a dead set). They need to be replaced. If they are black, take it to a repair shop.
Jun 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W15 TV Logo
406 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
