RCA HD52W59 APPEARS IN 3D, I DON'T KNOW WETHER TO REPLACE FUSES OR DO I NEED MORE TO FIX THE PROBLEM?????? PLEASE HELP ME!!! -MOTHER OF THREE
    Champion:
  • 230 Answers
Hi, thank you for visit fix ya.
Common problem on this tv, Loose connections-and open fuse.
Re solder all connections around fly back, and replace a little fuse located beside fly back ( is a little brown box), you will See 3 fuses parallel beside fly back; replace fuse 400ma.
Thank you
Posted on Jul 28, 2009
I had 3 pictures in 1 and a bowed 3d screen. I replaced the fuse and re soldered the flyback. The picture looks good now but I still have the 3 in 1 picture?
The problem in in the convergence circuit not the horizontal area. There should be 2 large black ICs inside marked STKxxx. These are the convergence ICs. Try resoldering the pins on these first. Should that not resolve the problem, replace the ICs.
Please keep us posted on your progress.
Dan
Jun 13, 2010 | RCA HD52W59 HDTV Projection Television
My rca hdtv has a 3d look, and it is blurry, what can i do
this 3d look is coused by bad convergance ics you have to replace them no adustment will fix this
Dec 24, 2007 | RCA HD52W59 HDTV Projection Television
I have a rca hd52w67 projection tv and the screen looks like it is concaved,has three lines across the top and looks like it is in 3d. What is wrong with it?
The convergnce amplifiers have failed.
This is a common old-age problem.
This requires replacing the convergence amplifiers and possibly resistors and fuses. A repair shop would charge $300-$400 to repair.
If you are tech savy or know someone who is, thae parts will cost around $40.00. Search this site for specific instructions.
Good Day,
-Dan
Sep 10, 2009 | RCA HD52W59 HDTV Projection Television
OUR RCA HDTV HD52W59 LOOKS LIKE IT'S IN 3D
You need to replace FL231 and resolder the flyback.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 01, 2009 | RCA HD52W59 HDTV Projection Television
Screen is in 3D
If the convergence option has disappeared from the on screen menu you wll need to replace FL231, DL231 and CL230 total cost about 12.00 parts come with instructions on how to install. The following link has them listed under the RCA parts category.
http://servicemanuals.vstore.ca/
Jun 13, 2009 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 3d screen colors are seroperated no convergence
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 12.00 shipping is free. the parts are all listed under the RCA parts category.
May 28, 2009 | RCA HD52W59 HDTV Projection Television
COMES ON BUT TURNS RIGHT OFF
3 bad capacitors located in front of deflection board cp150 2200uf 16v replace all 3 they will be green with gold writing on them.
Nov 22, 2008 | RCA HD52W59 HDTV Projection Television
Please help me
Hello i just posted detailed instuction on the fl231 problem. scroll down to the tips for the hd52w59 or in my profile under tips. if u need any extra help just let me know
Sep 19, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Wavy lines
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
