Back to:
Tags:
Compaq 187498-001 Motherboard
Looking for a part time motherboard tech in Texas
By Rachel007 - usenet poster
I am looking for a part time motherboard tech in the DFW area. I have
over 100 PC motherboards that I bought. They are mostly Compaq and
were sold to me as a mixture of shelf pulls and returns.  Some of them
have notes on them describing a return problem and some have no notes
at all.  I am looking for someone that has the ability to test and
possible repair these motherboards.  Here are some of the model
numbers in the batch:
237353-001,     233567-001,     222109-001,     251368-001,     010561-101,
46991,  3T237, and      187498-001
Compensation would be worked on a percentage of the final sell price
of the items.  I plan on offering them on eBay and would like to be
able to offer most as 'working motherboards' which will enhance the
value of the boards.  The motherboards are located in Denton, TX
If interested, email me so we can discuss the possibilities.
Mikel Giles
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
Perkins
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi!
I've checked the model numbers you've given, over half are for
notebooks! I've previously worked with one of Compaq's OEMs in Taiwan as
an RMA board level repair tech for their Presario line.
Sorry but I have to say that you need access to BIOS for different board
revision, replacement ICs of the right revision, complete documentation
of the boards and the right equipment. I doubt you have any of the
above. Majority are not easy fix like replacing an electrolytic
capacitor or cleaning contacts.
I suggest you sell them "as is" and forget about the whole repair idea.
Jovit
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on looking for a part time motherboard tech in Texas:
I don't want to Accept this solution
Solution #2
Not Rated (0)
jessie25
Rating: 0%, 0 votes
hehehehe...Compaq ?? umm...serves ya right... :>)
seriously...get the boards crushed and write off to tax loss...no serious
tech would even consider what you're asking as any viable proposition. These
boards will most definately be proprietory, have customised bios etc and
there isn't a chance in a million you will have access to the gear needed to
even successfully test them. I suspect there is a compaq engineer smiling
right now at your post...
regards
Alastair
Thank You!
Solution #3
Not Rated (0)
Ranny
Rating: 0%, 0 votes
Seems like everyone is smiling but me :) I bought the boards because I
thought most were shelf pulls and then found that I had 'BEEN HAD big
time and decided to look into how to figure out if any were good.
They were listed as a mixture of RMA returns, shelf pulls, and just
returns.  Most have mfg reject tags or RMA sheets with them.  Some
were not marked at all but I am afraid that they are RMA or rejects
with the markings missing!
Thanks to all for the replies.
Mikel
Thank You!
Solution #4
Not Rated (0)
Brad
Rating: 0%, 0 votes
Throw them away, they are worth very little if they need any repairs at all.
What kind of repairs do you really expect to be performed on a multilayer,
high density board with absolutely no service information available.
The boards with the capacitor problems are even getting old enough that they
do not warrant much time on the labor side to fix.
Any quality tech with the skills and equipment to do what you want is going
to require a minimum of $30 per board just to check it out!!!!!!!!!!!
Thank You!
Solution #5
Not Rated (0)
pandamama
Rating: 0%, 0 votes
You shouldn't have bought the boards.
First off, they're Compaq.  These boards are likely to be of the proprietary
type instead of being industry standard ATX.  You'll have to find the right
kind of computer cases to install these boards into and these boards may only
work with a limited selection of CPUs and memory.  If you only have the boards,
then you'll have a hell of a time trying to locate cases that will work.
Motherboard repair can be both complex and expensive.  Most of the time,
serious problems, such as a failure of the northgate, southgate, or BIOS may
not be worth repairing.  In the case of Compaq boards, they may be next to
impossible.  You may not be able to obtain replacement chipsets of the exact
kind needed by the mainboard, even from the original supplier.  Replacing the
BIOS with the specific type needed by the board may be impossible.  Impossible
because Compaq may not have replacement BIOS chips for sale and also that it is
very likely that the BIOS is wave soldered in place instead of socketed, which
makes replacement all the more difficult without risking damage to the board in
the process.
For the services that you ask, you aren't offering enough.  I don't mean to
sound snotty but that's a fact.  For the funds needed to pay a competent tech
to repair the boards along with parts and the labor to build up computers to
sell, the price you may have to charge to pay for all services to make the
computers may exceed their actual value.  - Reinhart
Thank You!
Can you Help with these Motherboards problems?
Motherboards
I have had this in for service and I have been told that...
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
