Question about Dell Office Equipment & Supplies
Power cable missing - Dell Office Equipment & Supplies
  • 346 Answers
Most printers require that you purchase a printer cable. It has a USB on one end and the other end looks square. If you want one that plugs into your USB port it is called a USB 2.0 A - B Scanner Printer Cable. They come in different length. The longer they are the more they will cost. You can get them off of Ebay by searching Printer cable. If you will be plugging the printer into a parallel port make sure you get a printer for that kind of port. You can usually purchase printer cables at any store that sells printers or computer parts. They are a pretty common item. Hope this helps.power cable missing - moz-screenshot.jpg
Posted on Jul 28, 2009
Got 40 in apex lcd flat screen tv and looks like its missing the power supply board anyone help me
some models have a external transformer like power supply. Cable plugs in wall socket goes to power supply transformer, cable from transformer connects to TV with a male female probe type fitting. It appears the power supply is missing.
Mar 04, 2016 | Televison & Video
Im missing what plugs into p3 and p4 what is it i am missing
I would need more information on your PC but this is what I think you're talking about:
You should have two cables connected to the CD\DVD drive and the hard drive. One of these cables is the data cable and the other would be the power cable. The data cable would be a smaller cable connecting to the hard drive and to one of the Sata ports on the motherboard while the power cable would come from the power supply and connect to the Sata hard drive.
This would be the same for the CD\DVD drive. This only applies if these are Sata drives and not the older IDE drives.
The Sata connectors have a L shape design on one end so they cannot be inserted in the wrong polarity.
You may not need all the power cables coming from the power supply as some may be for any added drives that you may not have.
If the power cable is disconnected from the hard drive, the system would not boot. You might want to check the memory modules also, to make sure you have them inserted in the slots completely.
Mar 30, 2015 | Computers & Internet
My power button cable is missing so i plug into the wall pc starts up no noise but fan amber light but black screen graphics card fine?
Dont worry about on/off cable. if you have restart / reset button, remove that cable from motherboard and insert it in power on pins and use reset button as on/off switch.
Jul 22, 2012 | Dell XPS 700 PC Desktop
My partitions are missing.D E F-all these three are missing help me.
If these partitions are on a hard disk other then your C: check
1. jumper settings
2. power cable going in the hard disk
3. change the data cables
Aug 02, 2010 | Computers & Internet
Power cable tip is missing
standerd replacement lead availible from most auto stores dont use no garmin as they may not be compatable
Dec 04, 2009 | Garmin nuvi 200W GPS Receiver
Tally 6100 missing lines
horizontal or vertical characters missing???
if your missing horizontal lines, look at where the print is missing if you see imprints... u have bad ribbons.
if your missing vertical characters down the page
Power off the printer & unplug from wall
Remove with phillips the top right cover. u will see that the control panel has a plastic clip needs to be pressed in for the control panel to come loose from the top right cover.
Then you will see P703 Hammerbank Ribbon Cable and
P704 Hammerbank Ribbon Cable swap these 2 cables on the Engine Controller Board part# 083368.
IF your missing characters move to another place on the printout then u will need to replace part# 083368.
IF your missing characters are still in the same place, then you will need to replace hammer module part# 081152, their is qty 11 of the individual 081152 about 1 inch wide. this will save $$$ ordering and replace 081152 if you have some at your work semi technical.
Be very careful with hands when powering the printer with the top right cover off
Electrically and mechanically.
Need more help you may call Toby at x311
Apr 24, 2009 | Tally Line Matrix T6100 Printer
Please help for Cable and Power supply for KOGI monitor L7EH-TA ???
the power cable is as the simple attach to run the pc..
the vga cable u have to buy it from computer/monitor shop..
ask them for cable by telling them the model and spec. of your monitor.
regard,
dont forget to rate it
Jun 14, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Micro solutions Back Pack
It's a standard DB25 pin cable. Male on one end female on the other.
What's the voltage of the power supply for your unit? Mine is missing the power supply. (kids)
May 17, 2008 | Micro Solutions (212010-USA-INT)...
55 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
