Question about Hoover Vacuums
How to put cover/hood back on hoover u5018. Help please
  • Hoover Master
  • 1,420 Answers
Hook the cover at the front and rotate onto the vacuum, the twist the two connectors with a coin or large screwdriver to hold it on.
Posted on Sep 08, 2017
The belt is broken on our Hoover Allergen Filtration Model U5018-900 120 v. 60 Hz 12.0 A. Belt 38528040. Where can I get the belt and instructions on how to replace the broken belt?
The owner's manual can be downloaded here (in red, "Download the Instruction Manual (PDF))
Instructions for replacing the belt are on page 9.
You can order the belt here:
Or use the "Retail Locator" on the first site.. Just type in your zip code, and a store that carries Hoover and products near you will be shown.
Oct 07, 2010 | Hoover U5018-900 Bagged Upright Vacuum
How to change a belt
look on the bottum of the machine you should see 4 screws there should be arrows next to them remove them and pull the base plate off remove the old belt put the belt on the drive shaft then put the belt on the upper wheel it might be a little hard but just roll it on useing the wheel
Jun 28, 2010 | Hoover U5018-900 Bagged Upright Vacuum
No Power HOOVER U5018-900 bagged upright Vacuum
Check the opening behind the floor brush for obstructions there.
Nov 09, 2017 | Hoover U5018-900 Bagged Upright Vacuum
Lost my user manual
Can't find manual. Belt broke, replaced it now no suction. Have checked for clogs none found.
Jul 26, 2008 | Hoover U5018-900 Bagged Upright Vacuum
Removing the hood to clean the cleaner
Posted by bfy1952 on Apr 08, 2008
How do I remove the cleaner hood the clear see thru plastic to clean under the hood?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5881-900 Vacuum. There may be 2 ways to remove the top cover. There are two screws located on the bottom and there are 2 ways that might work. The clear tube on Hoover’s sometimes will swivel and that is the way to bet the clear tube unclogged, or once you remove the 2 – 4 screws on the bottom the top should lift right off, and then you can serviced your vacuum cleaner. If you have questions you can always contact your local vacuum cleaner dealer in your area or call tech support @ the Hoover @ the factory and ask for tech support.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 08, 2008 | Hoover F5881-900 Vacuum
Hoover Encore Supreme belt replacement
Remove the bottom plate that covers the brush roll and remove the roller. The plate is removed by releasing two clips at the back corners of the plate on either side. Take the roller and install the belt around the pulley and put the other end of the belt through the access hole in the vacuum body. Replace the roller and turn it by haand to ensure that the belt is not pinched. Replace the bottom plate and turn the roller again (same reason).
If you look at the area beside the rear wheel between the hood and the main body, you will see a clip incorporated into the hood. Take a screwdriver and pry it away from the main body. Do this on both sides. You will find a similar clip at the hood just beside the back corner of the plate in the front where the plate clips are located. Pry these as well and hood will come loose. Now you can turn the machine back on its' wheels and remove the hood. You will see the belt where it comes through the main body and you can grab it with a couple of fingers and stretch it onto the motor shaft. Replace the hood and the job is done.
Mar 21, 2008 | Vacuums
Hoover belt replacement
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
Dec 19, 2007 | Vacuums
How to change a Hoover Elite sweeper belt
on the bottom there should be a few screws take them out and a cover should come off the belt is right there. hope this helps
Dec 18, 2007 | Hoover Elite U5061-900 Bagged Upright...
Vacuums Logo
42 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
