My samsung model#txp273x/xaa will not come on,timing light is flickering, i have never used this fetcher, please tell me what to do....the TV is hooked to a digital cable box
  • 3,037 Answers
This sounds like the tv is flashing a trouble code. How many times does it blink? This will help determine what is wrong with the tv. Thanks
Benjamin
Posted on Jul 28, 2009
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Samsung 61
If using a cable or sat box try a DVD etc when set cold, a box can cause lockup issues via signal.
Not a color wheel is correct, more likely a DMD which is rather pricy and almost as much as the entire light engine which comes with it.
Oct 12, 2012 | Samsung HLP6163W 61" Rear Projection...
Model Number HLT5676SX/XAA 56" Samsung
your question does not help us or you as we do not know your problem .
Jun 09, 2017 | Samsung DLP HL-P5663W 56" TV
I have a samsung flat screen model # LNT4665FX/XAA that is about three years old, when I turn it on it clicks about 6 times before coming on. What could be the issue? It also seems to flash pixels...
Your TV most likely has faulty capacitors in the power supply section of the TV. This is a failry common problem.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
2c07611.png The number one cause for the symptoms above are faulty capacitors within your Plasma or LCD TV. The number one reason that these parts fail is that TV manufacturers often times use lower grade capacitors in their efforts to reduce costs. After several years these lower grade parts will tend to fail first. To insure that these parts will not fail again its imperative that they are replaced with high temp, high quality, low-ESR caps. You can find the parts online from sources like Digikey or you can get complete reair kits incuding the parts, repair instructions, and support from www.TvRepairKits.com
Dec 15, 2010 | Samsung LN-T4671F 46 in. LCD Television
The LED indicator is flashing/blinking we replaced the lamp and it will not still turn on. someone suggested the cooling fan? Thank you Shawna2735@Gmail.com
If Fan is running when you turn TV on and keeps running then its OK ,Ballast Board is what turns Lamp on, Is Lamp Lighting at all?
Encompass Parts Distribution has Ballast board for $62.00
Be sure to give the whole model # to TV Ending in WXXaa
WAX/XAA or WX/Xaa HLR6167wxxaa or wax/xaa or wx/xaa
1-800-638-3328 You can also go to their website and type in your model # for List of Parts and Free Service Manual.
Sep 28, 2010 | Samsung HL-R6167W 61" HDTV
I have a samsung model hlr4667wx/xaa picture freezes
analog board can cause that symptom especially if the pic is freezing .
Jun 26, 2010 | Televison & Video
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung LCD TV doesn't power on, just blinks 5 times
After about 5 years the Samsung LCD televisions backlight fails which prevents the TV from coming on and the powerlight just flickers the backlight can be changed but it is often alot easier and cheaper to buy a new Television
Sep 14, 2009 | Samsung LNT2642H 26 in. LCD Television
I have a Samsung HDTV. Model Code HLR4667WAX/XAA,
IT'S YOUR DMD MODULE IT'S PART OF LIGHT ENGINE IN THIS PATICULAR MODEL WHEN THAT GOES BAD YOU HAVE TO REPLACE WHOLE LIGHT ENGINE CONTACT DISCOUNT MERCHANT OR RIVER VALLEY ELECTRONICS THEY HAVE THEN FOR PRETTY CHEAP.
Jun 24, 2009 | Samsung Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
