Kenmore top load washer-- water will not turn off even after machine is turned off. Please help
    President:
  • 1,776 Answers
It sounds like faulty water inlet valve solenoid, Replace water inlet solenoid valve assembly. Check them for continuity. If the meter reads zero ohms, the solenoid is open and must be replaced. Hope this helped and best wishes.
Posted on Jul 28, 2009
F error code "kenmore top load" washer oasis he3
Hi
LF means Long Fill, this error flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change. Check whether water supply is connected and turned on. Make sure the hose is not blocked and hose screen is clear. If so make sure pressure hose connection to machine/motor control is fine. Also check the continuity of water inlet valve, use a multimeter to check the continuity. Hope this helps... Please post back if you need more information.
Daniel
Feb 16, 2011 | Kenmore Washing Machines
Water dripping
Turn the water off at supply valve, this will stop the water. Then you will need to replace the fill valves on the washer.
Jul 05, 2010 | Kenmore 24032\24036 Top Load Washer
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
Bill
May 22, 2010 | Kenmore Washing Machines
Washer won't spin or agitate
hi, Does the water drain out in the spin cycle? Sounds like the coupler might be bad. Is this a top load machine? Asking questions so I can be clear and give you better info on your question.
Please let me know.
Thanks
Vic
May 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 model 110.20912991 wont stop filling with water
If it continues to fill turned off or even unpluged, It needs to have the water valve replaced it is sticking open.
Jan 27, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore Elite front load washer filling up while turned off
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore washing machine
It looks like you have a water filler valve problem, with your washer emptied turn the water faucets back on and turn on the washer, if it starts filling turn your timer knob around several times, like you were hunting a cycle you wanted to use. This may make something dislodge from the valve.if blocked If not try the same thing with your water control knob. turning it from hot to cold and then to hot again......I hope these work.....check equally the hose and if that is your problem you may need a new water valve.
Aug 31, 2008 | Kenmore 80754 Top Load Stacked Washer /...
Washing machine
it needs a new water valve
Nov 16, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
