Question about GE GSH22SGRSS Side by Side Refrigerator
Broke one of the arms on the device that pushes the ice cubes out. Any ideas?
    Novelist:
  • 108 Answers
You mean this?
http://www.repairclinic.com/SSPartDetail.aspx?s=a1b3c248i301130&PartID=301130
Posted on Jul 28, 2009
The Ice maker has stopped working.
There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
Jun 18, 2010 | Maytag MFI2568AE Side by Side French Door...
Ice maker will not stop,even when the tray is full of cubes.. will only stop if arm is put up..
The ice tray arm is mechanical. It is pushed up by the ice cubes. Try bending the arm down so it makes contact with the ice cubes sooner and gets pushed up sooner when it reaches up posistion it should stop.
Mar 29, 2010 | GE Profile 24.7 cu. ft. Top Freezer...
Icemaker makes ice, but will not dispense ice via door.
The auger arm in the back of the freezer should be rotating to test this hold the door switch in and push the dispise button down. If it does not even try it could be the control switch on the door. the auger motor is a 120v motor and relatively strong. You can test to see if you can manually turn the arm it should trurn stiffly. Its alsoi a chance you don't have the been in place correctly.
Jan 10, 2010 | Frigidaire FRS23R4A Side by Side...
I have my indoor ice dispenser set for cube and it only dispenses crushed. How can I get it to reset back to cubed ice?
Easy fix.
Pull the ice bin out a couple inches.Look underneath the ice bin at the back wall of the freezer. You will see a hole in the back wall with a yoke device in it. The underside of the ice bin has a metal arm attached. The metal arm must go inside the yoke in the back wall.
Push the ice bin in until it seats in the locking tabs and the arm is inside the yoke.
Nov 20, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fridg is making ice (ben is full to capacity) but does not dispence propperly, it is crushing cubes and is frosting up.
The ice cube bin has become dislodged from the locked position.
Pull the bin out and re-insert the bin into the frame locks.
Look underneath the bin when you push it back in. There is a yoke device in the back wall of the freezer and a metal arm on the ice bin. Make sure the metal arm goes inside the yoke.
Make sure the ice bin feels locked in place.
Oct 28, 2009 | Hotpoint HSS25GFP Side by Side...
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
Crushed ice only.No cubes.
Pull the ice bin out about 4 inches and re-insert it in the slot in the rear to reset the crusher arm.
Mar 11, 2009 | Whirlpool GD2SHGX Refrigerator
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker will not push out ice cubes once frozer
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The heater, or evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
May 12, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker does not stop working and overfills, then ice dispenser does not work and pushes door open.
Continuous ice production, too much ice in the bucket, ice cubes overflowing the bucket, ice cubes falling behind the bucket or ice lifting the chiller shelf can now be resolved by installing a redesigned feeler arm. The new arm is designed with a slight curve to cycle the icemaker “OFF“ before the cubes overflow the ice bucket. Order part number WR49X10103.
Jan 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22SGRSS Side by Side Refrigerator Logo
42 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
