Question about Whirlpool Kitchen Ranges
How to replace an element on a electric free standing flattop
    President:
  • 1,273 Answers
If it a coil type element, all you need to do is identify where the leads from the coil go into the socket underneath the lid of the stovetop. You'll be able to see it from the top. Once you have identified that spot, lift the burner opposite of the leads just enough to clear the pan, and pull away from the socket.
Best regards, --W/D--
Posted on Jul 28, 2009
Kenmore 790.9641* free-standing electric range: The "single" (inner) part of the dual radiant element is not working. When the knob is turned to the single side, the ELEMENT ON indicator lights, but
The inner ring or center part of the element is burned out. You will need to replace the entire element, as it is not possible to replace just part of it.
Dec 19, 2014 | Kenmore Kitchen Ranges
Magic chef smooth top electric free standing oven temperature
Most likely a bad temperature sensor if the bake element is coming on and not reaching temperature.
The temperature sensor is in the back wall of the oven up high on the right or left side depending upon your model number. It is about 3 inches long and about the size of a thin pencil. It removes from the inside of the oven.
Nov 19, 2009 | Kitchen Ranges
AEG Dishwasher 54850 not heating up the water is no getting hot
This could be the electrical element (some use the old traditional element and some (later models) use inductive heater coupled in line with the hose feeding the top sprayer arm. A test with an Ohm meter should indicate if the element is open circuit.
Aug 02, 2009 | AEG 18 in. Favorit F54850 Slim-Line...
I want to replace the top grill element in a zanussi zhq 575
Regardless of wether it is built in or free standing you will have to remove the rear panel, possibly the top cover as well.
The element may be fastened from the inside of the oven .or on the outside at the rear, depending on which way the screws have been fixed.
Undo the fixing screws, disconnect the wires taking note of the connections ,this is very important, and withdraw the element from inside the oven.
Fit new element in reverse order, it is a fairly straight forward repair to do..
Plz rate my solution.Thanks.
Jan 03, 2009 | Zanussi ZHQ575 Electric Double Oven
Dishwasher
its either the element or the motor, check element for visible signs of damage then if ok remove wires from it and ( making sure to insulate them ) and run the machine if it works then the element needs replacing. and if it doesnt then its the motor.
Jan 01, 2008 | Candy 24 in. CD622 Free-standing...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Whirlpool ADP4504- power cut when turned on!!!
could be that the motor is locked up (mechanically binding and wont turn) causing it to draw a lot of current, i.e. more amps than your breaker is sized for. is there any burning electrical smell?
Jul 11, 2007 | Whirlpool 18 in. ADP530 Free-standing...
Kitchen Ranges Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
