Question about Nespresso D150 Espresso Machine
Leaking system frother
Our 2 year old espresso maker is leaking from the frothing unit when machine is on. is there a replacement part to fix this?
  • Muzikluvah Jun 12, 2008
    this machine does not have a screw at the bottom, the black tip comes off to clean, but there is just a spigot. the arm goes directly in the machine.
    thank you for tryin'!
Is the frothing wand completely screwed in? You can actually unscrew it (or partially unscrew it) by moving it slightly when you're cleaning it. Twist the black tip, at the very bottom, and you'll find that you can screw it on & off. Make sure it is screwed on tightly & it shouldn't leak.
Posted on Jun 12, 2008
The frother doesn't froth. I start with cold milk fill it to the hot froth line and push. The red circle lights up and whirls around, but when it stops there is no froth
I have tried tilting mine slightly, just a 20c peice under one edge of the base put enough of a lean on it to make the milk froth. Shouldn't have to do this, I know. I am having similar issues becasue I don't think I should have to alter the unit. Mine is 2 weeks old.
Feb 15, 2011 | Nespresso Aeroccino Automatic Milk Frother
Poor frothing
You need to check (or replace) the air-intake nozzle which is located inside the coffee outlet. You will sure loose the good froth if that part is not clean or replaced. There should be proper amount of air input to produced the proper froth.
Rihel Calma Philippines
Aug 22, 2009 | Franke Saphira Espresso & Coffee Maker
Missing milk frothing tube
should be listed in the owners manual with a part number
Aug 14, 2009 | Coffee Makers & Espresso Machines
No water or steam is coming out of the frother. Tried rinsing machine and going back and forth from brew to froth with no results.
Just fixed this same problem by taking apart the water solenoid valve and cleaning out its connection tube of deposits that was blocking water/steam flow. I removed the magnetic coil but that's not required. The connector was very tight because it had loctite sealer on the threads. I used plumbers teflon tape on the threads when reassembling.
May 11, 2009 | Jura Capresso C1300 Coffee Maker, Espresso...
No steam when valve opened, spits out water in the beginning of frothing
There is a small teflon piece on the inside of the steam tube, you will have to disassemble the frother to get to it. Remove this piece. Reassemble and the wand should work fine.
May 08, 2009 | Gaggia Syncrony Compact Coffee...
Nespresso D150 Espresso Machine Logo
262 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
