Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Have heat & tumbling but will take 3 hrs to dry a load/ no jeans
Whirlpool ultimate II dryer. takes 3 hours to dry regular load of clothes, regardless of setting. Jeans I have given up and dry outside in the sun. This is a new dryer. when I open up dryer, it is like a steam bath. Very Moist Heat. sometimes I will get a exhaust/ burning smell.
Likely that your Dryer vent is clogged up. Especially if its long. Check that by hooking up a shopvac to one end with duct tape to seal any air leaks between the vent pipe and the vac hose. Turn it on and check the other end of the vent pipe for suction. If its faint then there may be a crapload of lint in there or a birds nest. Compressed air in the pipe with an agitating device may work or shopvac hose if run is short. Be prepared for a mess on either end.
Heather
Posted on Jul 28, 2009
Whirlpool Gold Ultimate Care II Gas Dryer takes to long to dry
sounds like ur t-stat is bad or maybe a thermal fuse. hard to say w-out diagnosing in hands on.
Jul 25, 2013 | Dryers
The Whirlpool Ultimate II dryer heats up at first and then the heat shuts off after approximately 10 minutes and doesn't come back on. If I let dryer cool for 10 minutes it will do the same thing again.
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 14, 2010 | Dryers
Whirpool dryer takes 3 hours to dry jeans or towels.
Most likely your heating element has partially failed. Some dryers have two separate resistance heaters in them. If one fails what you are describing can happen. If you have the tools and are willing to take it in it's not that bad a job. You have to take the cover off the dryer to see it, then it is two bolts. Any appliance repairman can handle this easily.
Mar 22, 2010 | Whirlpool LER5636P Electric Dryer
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
Not heating and drying clothes properly takes about 2hrs to dry jeans??? what is the problem
frist check the vent if this is to difficult for u pull vent hose from dryer run dryer with load 45min normal dry time . longer for jeans 60- 70 mins. if this works. u have vent problem. if not remove back of dryer replace cyle tstat this is one closer to vent duct problely 4 wires
Oct 26, 2009 | Whirlpool LER5636P Electric Dryer
Heat works and tumbles fine, but the clothes do not get dry
Hi, First thing you need to check is the vent that goes outside. Make sure it is not pinched or plugged in any way. If it is an electric dry, you can try one load without the vent if it is in a ventilated area so that you don't get a lot of humifity.
Please let me know if I have helped or if I can be of more assitance.
Thanks
Vic
Apr 06, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool ultimate care II dryer will not dry clothes
does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool ultimate climate II electric dryer the drum turns and the heat works but it take almost two hours for the clothes to dry can u help me.
Hello, please make sure that the dryer vent is clear and blowing properly . If not this causes the heater to short cycle which in turn increases your drying times. good luck
Dec 23, 2008 | Dryers
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
326 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
