Whenever I start to sew, the thread just jumps out of the needle. If it does start, there are no stitches on the fabric or there's a bulge of thread on the underside of the fabric. I need help please. It is a fairly new machine. Thanks
Start slowly, make sure your thread trails are long enough, I had this problem a LOT when I first started using this machine. (mainly because it was my first machine!)
Fabric bulge- Don't try to push the fabric through the machine, let the feed dogs do it. Your job is to guide the fabric.
Thread jumps- Also, like Outdoorsman said, the tension is probably off. On this machine, the tension knob is easy to find. It's the small one with the numbers on it. "0 1 2 3 4-5-6 7 8 9" 4-5-6 are your optimal sewing tensions. I usually sew on 4 or 5, depending on my fabric and type of stitch.
No stitches- Your lower thread may not be being grabbed properly/bobbin case may be jumping out of position. Open the lower case and make sure your bobbin case is secure, and the thread is grabbed properly.
Hope this helps!
~iamtyping
Although I am not a expert at sewing machines, I have worked a lot with an industrial sewing machine. You might check the tension of the thread that goes through the needle. If it is to tight it will pull it through the needle. There should be somewhere on your machine that you can adjust the tension.
