Washing Machines Logo
Why is it displaying the LD code - Washing Machines
Why does my washer wtw6200sw2 display an Ld code?
The Ld code is Long Drain. You might have a clogged hose. I had this problem once with mine. We had to empty the washer by hand and turn it on its front. Make sure you unplug it first! There is an elbow that I think was attached to the pump. We popped it off and it was clogged with dog fur (from washing dog bedding). Cleaned it out and put it back on and that took care of it. I found the diagram of the system online and suggest you look for it too - my memory isn't what it used to be - it'll tell you what to look for and where everything is. It could be the pump, too, but hopefully just a clogged hose.
I have a whirlpool washer. model G V W 9959KQ. It is giving me an LD error code.
The LD error code means LONG DRAIN time and usually the reason it displays that code is because something it caught in the drain pump,thusly since something is in the pump its taking a very long time to drain the water.
GENE
1helpful
Flashing Ld on display
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by that fancy lectronic control.
Check these things out:
Drain pump fouled/clogged
Drain hose too high for propah pumpin.
Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Cabrio Manual
More topslosher failure codes and explanations are HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
3helpful
What does error code LD mean?
"Ld" Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. please remember to rank how this opinion has helped in your appliance situation and if you have any more questions please message me back thank you again and have a nice day
rickead1
2helpful
Ld code on my whirlpool cabrio, won't drain water, what do you do?
Hi There
OK here's something you can read to help you with. I hope this helps.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
4helpful
3answers
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
1helpful
2answers
THE MACHINE KEEP ON DISPLAYING THE CODE SC0322 (COPIER RICOH AFICIO 1045 MODEL). HOW TO FIX THAT PLZ?
Ld unit problem. This code can be very frustrating, as it can be triggered by several things -top right door switches shorting out, toner on the LD unit board, laser synch board problem, bad connection between the BICU and the LD unit, etc.
The bottom line is, if you're not a technician, you will need one to solve this error.
Make sure to always perform the LD pitch adjustment (both 400 and 600dpi) after doing any service to the laser unit.
1helpful
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
1helpful
LG LD-12AW2 ( Not 12BW5 ) Error code E3 shows.
WTF, do you have any solution on this stinking website
LD model LD-14AT2 dishwasher
Are you getting an error code displayed when this was happening?
How did you fix the problem?
Top Washing Machines Experts
john h
