Question about Samsung Televison & Video
Need wiring diagram for samsung sp43j8pf rear projection tv to put repaired board back in the board is where main power lead goes in thanks
  • seawanderer Jul 28, 2009
    i think this will be very helpful
    Sergeant:
    Novelist:
  • 198 Answers
I couldn't find a schematic diagram for the exact tv model that you have but one person who has the same tv model that the tv's chassis model is J51A/J51B based on the sticker he found on his TV. Other tv models using this chassis are SP53J5HFX, CP61J5HFX, SP54J7PFX/PFC, SP43J7PFX/PFC.
You may download their schematics on this site:
http://www.ddrservice.net/catalog/TV-Set/samsung/
Here's for SP53J5HFX (Chassis J51A)
http://files.ddrservice.info/TV-Set/samsung/sp53j5hfx_awe.pdf
Hope this helps!
Posted on Jul 28, 2009
Won't power on.
it may not be a fix but here goes,before this answer MAKE SURE THE POWER IS NOT ON, note where the switch is and follow the wire to main boaed, look for a plug on the end of the wire lift the plug and put it back on a couple of times also press the power seitch on and off do this a few times fast, hope this help's, paul.
Feb 14, 2014 | Televison & Video
I have a Samsung HLN437W DLP TV I turn it on and in about a minute there is no picture or sound and you have to turn it off you have to unplug it
That problem is usually have 2 causes..Its either power supply board or main board..
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Thanks for using fixya...
Dec 23, 2011 | Samsung HLN437W 43" Rear Projection HDTV
AKAI rear projection TV won't turn on
possiblity convergence needed...
main power board malfunctioning
contact akai service center
Apr 26, 2010 | Akai PT4298HD Rear Projection Television
Samsung 50" rear projection tv switches off after a few seconds
probably need to replace the Ballast and Power Supply Board. If lamp has not been replaced, I would replace that too. can call 1-800-samsung for nearest service center.
Dec 29, 2009 | Samsung HLN5065W 50" Rear Projection...
The light is on in front of the tv but not picture or sound
THE PROJECTION FUSES R BLOWN,U NEED TO VERY CAREFULLY TAKE BACK OFF /UNPLUG TV FIRST!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!/THEN RUN FINGERS DOWN WIRES COMIN FROM PROJECTION THAT LEADS TO FUSES,REMOVE THEM,TAKE TO RADIO SHACK AND GET MORE THAN REPLACE THEM
Jul 15, 2009 | Samsung HCL4715W 47" Rear Projection...
Turns on and within a second goes out
Bad capacitors. They're cheap. Look for the ones closest to where the power cord comes in to the main pcb board. This will be your power supply circuit. Change them! They're probably dried out. If they're bubbled up, they're also bad. They're so cheap though, just replace them all.
May 21, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Rear projection tv
I would need your model number in order to help you with the problem. Please respond to this same post with the model number.
Jul 09, 2008 | Televison & Video
Vertical red line, tv turns off
If your looking to service this set yourself you need to open the back cover and look down on the main pcboard with a flash light if you see any liquid damage it's more then likely your CRT's are leaking coolent fluid on to the main PC board, Common problem with most CRT projection TV's manufatured today, main board needs to be cleaned and the CRT's need to be sealed,
Feb 25, 2008 | Samsung HC-P5241W 52" Rear Projection...
Samsung Rear Projection
Hi.
Im certain I can help you there are basically 2 fixes that spring to mind for this fault.
First fix : RESOLDER IC801S ON POWER PCB.
SEVERAL PINS ARE DRY JOINT NORMALLY.
Try the first fix before attempting the more difficult second fix.
You will need soldering iron with a tip of approx 1.6mm & 0.7mm fluxed solder.
Take notes & pictures of pcb layout plugs & sockets before unpluging anything in side the tv set.
The first fix is easy you just need to find IC801S & resolder all it legs (pins) to the pcb. To find the IC follow the mains input from the switch to the PSU board The IC will be very close.
********** IMPORTANT ENSURE TV IS UNPLUGGED FROM MAINS POWER ********
TV SETS STILL HOLD ELECTRICAL CHARGES EVEN WHEN SWITCHED OFF.
IF YOU ARE NOT CONFIDENT TO UNDERTAKE A REPAIR ON YOUR TV PLEASE GET A QUALIFIED TV TECHICIAN TO DO THE WORK FOR YOU.
Second fix : CHECK R437(1.8 OHM) RESISTOR ON DEFLECTION PCB,
IF O/C CHECK IC501, IC531, IC561 ON CRT BASES FOR SHORT CIRCUIT.
http://dysonmanuals.llc.nu/
Chris..
Dec 30, 2007 | Televison & Video
Samsung HCN473W 47 in. Rear Projection can't turn on
i know this is a old problem but in case anyone in the future here has this problem, the problem lies in your convergence board ,mainly the stk`s are shot ,you can buy new STK`s for around 15 to 20 dollars and then will need some one to take old ones of and resoldering the new ones on.
anywho if you have this problem unplug or remove your convergence board and then turn on tv and you will see a picture, all colours will be out of convergence but when you put the fixed board back in colours should realign, or you may have to realign a little yourself.
only reason i am posting on this old problem is because was just given this tv samsung hcn473wx/xac for free and decided to fix it and it now works well.
micheal rose
Sep 26, 2007 | Samsung HCN473W 47" Rear Projection...
Televison & Video Logo
104 people viewed this question
Jerry Greenberg
Jerry Greenberg
