What are model numbers?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: Kitchenaid Superba compressor
The compressor relay is located on the compressor under a cover. Before you go to the compressor I would check for other problems that you can see and hear. If the compressor is running there is nothing wrong with its relay.
1. Check the condenser and make sure it is clear and free of dust.
2. If the compressor is cool or cold check for a bad temperature control.
3. Check the freezer compartment for frost on back wall.
SOURCE: Heat Pump Stops Working only in the Early Morning
I recommend getting electric back up heat to fix your problem. Like the other gentleman said, defrost is having to kick on too much. It's doing the best it can givin the conditions outside. If you don't have enough power supply for electric back up heat, then a gas furnace or propane furnace will work also, depending on your needs. Heat Pumps are a like a full time fan, they are designed to heat your home at a steady rate unlike forced gas units that turn on extremely high temps and then shut off... Ensure your charge is correct, givin your tempatures the unit sounds to be working correctly, however a second opinion is always a good piece of mind before you spend money on emergency heat.. Hope that helps..
SOURCE: Water dispenser worked perfectly for 9 months. Today, no water comes out at all.
hi michael! you may have to get out your owner manual and read about how to change the water filter. get back if u need assistance
SOURCE: AC roof unit stops cooling after rain
No, the units are sealed and the rain should not have affected the system at all. I would remove the outer cover of the unit and access the capacitors. Your start capacitor may be bad. You can visually inspect this and tell if there is a problem. Small black relay on top of capacitor often burns out, if so, replace capacitor and relay. If this looks fine, then we need to start at the thermostat and work our way forward.
Thanks,
Jeff
SOURCE: i have a toshiba 37 wlt 58 lcd tv . i watched the
Sections of the power supply may have gone out, or it detects short circuits in the backlight inverter board or in the power supply itself.
Those are the two areas you need to check. Look fo bad caps with leaking/bulging top fist in the power supply.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
