SOURCE: Gas oil ratio
normaly 20 to 1
but with some of the newer oils you need to follow the instructions on the the oil bottle the newer cleaner fuels are now mixed at 50 to 1
SOURCE: oil/gas ratio for a modle UTO8110 homelite leaf blower
you can run 32:1 if you want to it wont hurt it but it may foul a plug since its more oil, 50:1 is the best ratio for your blower
SOURCE: What is the oil type and oil/gas mix ratio needed
I always suggest using a full synthetic 2 stroke oil for these machines. It provides superior lubrication qualities and burns cleaner than conventional oil. The fuel/oil mix ratio is 40:1. That is 3.2 ounces of oil mixed in 1 US gallon of gas. Half that to mix up a 1/2 gallon. You can find this info and more in your manual. The fuel info is located on page 10.
http://dl.owneriq.net/d/dcedfb0b-6611-4152-bbbf-d793d087365e.pdf
You will need Adobe Reader installed on your computer to view your manual as it is in PDF format. If you don't have it, you can get a free download from their site. It is safe.
