Moveable clutch pulley exploded, plastic, and drive belt destroyed. clutch pedal very low no slipping when clutch pedal depressed no brake
SOURCE: Need a belt diagram
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=917.273638&pop=flush Enter your model # and search, scroll down to mower deck, and there ya are.It's an easy one. Straight across the back between the blade pulleys, then to the inside of both idler pulleys, then to the engine pulley. Hope this helps. Dwain
SOURCE: Need Lawn Tractor Manual-Craftsman
try sears.com
enterlawn and garden section
click on parts
enter your mod#
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
SOURCE: i need a pully and belt diagram to put the drive
These are a pain. You can go online with model number & get the diagram. Its the same as a John Deere. You will have to loosen the steering arm 7 rasie the steering wheel just enough to pass the belt thru. Make sure you mark its position for reailigning before disconnecting. Diagram should also be in your owners manual. Goo dluck with this one
