Question about Electronics - Others
I have a black and decker 1.7 cu.ft refrigerator its a 115 volts and 15 amp outlet and i am trying to put it in a semi truck. I am looking at a road pro 2500 watt. Do you think this will power it? And cool it down quick enought?
    Brigadier General:
  • 4,090 Answers
What wattage is the fridge Youy cant compare volts and amps withy watts.
If the fridge draws 2000 watts it wiull do the job but struggle as 2500 is the peak wattage and averages out at about 2000-2200 look at the back of the fridge. Just hope its about 15-1800 for effiecient cooling without strain on power source
Posted on Jul 28, 2009
    Problem Solver:
  • 5 Answers
I have used a 1.7 dorm sized fridge in my truck for years, first one i ran from a cherokee 1000 and it did fine, I could run it all night with the truck turned off and no problems. They draw about 180-200w on startup and abt 70-90w when running, altho I wouldnt go under 1000 watts with the inverter just in case.
Posted on Nov 01, 2012
Manual available?
SAMSUNG RS261MDRS/XAA USER MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > RS261MDRS/XAA
Samsung side-by-side refrigerator service manual (33 pages). Refrigerator ... 26 cu.ft. french door refrigerator rf267aebp user manual (ver.0.4) (44 pages).
Samsung - RS261MDRS - 26.0 cu. ft. Side-by-Side ...
www.searsoutlet.com > Refrigerators & Freezers
Rating: 4 - ‎228 reviews
Side-by-Side Refrigerator - Stainless Steel (RS261MDRS) at Sears Outlet today! ...Overview; Specifications; Manual & Warranty; Reviews ... 26 cu. ft. for greater space, convenience and access - Spacious enough to fit about 19 bags of ...
Jan 12, 2016 | Samsung Rs261mdrs 26 Cu. Ft. Sxs...
Won't stop running even on the off position on temperature. Freezes everything
the "o" position is as cold as you can get
try setting up around 4 and see what happens
Apr 29, 2015 | Black and Decker USA Black & Decker 2.7 cu...
Black and decker refrigerator model BCFA27B not working
Check any defrost water hasn't got into the electrics and blown a fuse.
May 28, 2014 | Black and Decker USA Black & Decker 2.7 cu...
Which way is colder on the temperature dial?
Turning thermostat clockwise lowers the operating temps.
Mar 14, 2014 | Black and Decker USA Black & Decker 3.3-cu...
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    How do i tell when the inverter is charged?
    Question does not seem to match this inverters capability.
    INFO:
    This Power Inverter converts vehicle’s 12-volt DC power into household 115-volt AC power. AC and USB outlets power and/or recharge personal electronics.
    We have owned one of these Power inverters for over a year now and have run a great deal with it, from TV to drill press PC and any thing that was small and that could run from my car. Very nice product.
    SET UP: Connect wires. ensure correct polarity, push button on top. Plug in 110 volt appliance.
    Hope this tip was of some use.
    R/
    David
    Feb 12, 2010 | Black & Decker Power Inverter PI400AB
    I have a kenmore elite refrigerator. Am trying to
    plan on 11 amps which would be 1100 watts and 115 volts.
    Oct 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Maytag M3X05F2A
    Your unit is 515 Watts using 115V (line to ground.)
    Maytag M3X05F2A
    Specifications:
    • Volts 115
    • EER 9.7
    • Amps 5.0
    • Watts 515
    • Plug cap. amps 125/15
    • Pints per hour 1.4
    • Room air (CFM) 160
    Room Size:
    • 10' x 15'
    • 150 sq. ft.
    If you plan on using it in the Philippines the electrical power supply is 220V line to ground. You can use an Auto Voltage Regulator (AVR) which has an internal winding with a servo that moves a carbon brush across the winding. I would recommend that you use at least a 1500 Watt AVR as the longer you use it the hotter it will get. Hopefully you can find an AVR with 3 pronged outlets. I currently use 3 ea. SIEG models SVC-888-1000 VA (600 Watts) for most electronics and 1 SVC-888-1500VA on a small 11 Cu Ft. freezer. The Freezer is 626W but uses almost 700W during the defrost cycle. The AVR failed after 3 years due to overheating. (STINK!) I also have a 4th SEIG model SVC-888-3000VA on my 21 Cu Ft 115V Refrigerator. There are other AVR manufacturers here and the cost vary greatly by manufacturer. (P3300 - P6500 depending on model) I have has all of my AVRs in countinous service for almost 6 years.
    Jan 13, 2008 | Maytag M6Q10F2A Air Conditioner
    Electronics - Others Logo
    1,020 people viewed this question
    Top Electronics - Others Experts
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
