Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
I was driving down the road today when all of the sudden the rpms went high the speedometer went to 0 and 2nd geer is the only gear i have now Ive talked to a mechanic and he sais its my ignition do you know if this sounds right and if it is what kind of part and money will I be into.
    Sergeant:
  • 308 Answers
The ignition may be is worn out or destroyed , that' s why the mechanic says that its the ignition .But the gear is different it is with the engine . try to check the first gear and the other gears ,because I think its in when you shift its not working or it is loosing or it is loose . Check and repair the gears or replace the gears.
Posted on Jul 28, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Please Help!!! 1999 Mercury Sable doesn't seem to accelerate past first gear..engine revs up to very high rpms.
If the speedometer stops working the odometer stops also. Sounds like it is stuck in first gear. The RPM went up because the throttle was response to pedal but transmission not response. Check transmission fluid color. Whip off dipstick on a white paper towel look for gray if see any that is metal shavings and transmission is bad.
Feb 16, 2016 | 1999 Mercury Sable
2005 chrysler sebring loses power driving up hill & RPM is up high, Ive changed, spark plugs & air filter. dont know what to do.
Not sure I am following your story.
Are you saying the transmission is slipping and therefore the RPM is high even tho the road speed is not ?
Or is the transmission not upshifting to the next gear at a normal road speed ?
Is the check engine light on ?
Feb 10, 2013 | 2005 Chrysler Sebring Sedan
SPEEDOMETER DIGITAL MILAGE READ OUT GOING ON AND OFF. BLINKERS WON'T CANCEL ON THERE OWN
The voltage regulator has failed if the voltage EVER rises above about 15.5 VDC. Surface voltage should not be as high as 13 VDC unless maybe the bike has JUST been shut off and then it should bleed down into the high 12's after about an hour of sitting.
The signal self cancellation is tied to the speedometer and the TSM/TSSM and so if one fails it will affect the other as far as signal self cancellation is concerned.
Aug 24, 2012 | 2003 Harley Davidson FXD Dyna Super Glide
High Idle and sputters while driving....
1st off if check engine light is not on then there will be any codes to check.... however you have a problem that is not being picked up by your computer... so u may have a vac leak... more air into engine makes rpms go up...
May 15, 2017 | 1999 Jeep Grand Cherokee
1999 AUDI A6 avant 2.8L quattro. Car vibrates
This is a manual transmission? If so the clutch probably needs to be replaced. When you say "VIOLENTLY" what is going on, what is the road speed, what are the RPMs at? The more specific information the better. And this problem ONLY occurs between gear changes, right? The other times, everything is normal?
Nov 11, 2009 | 1999 Audi A6
2000 GMC Jimmy SLT 4wd, 65k miles, baby'd, driven
bad transmission, it will need rebuilding or replacement. sorry....hopefully this helps
Aug 16, 2009 | GMC Jimmy Cars & Trucks
2000 grand caravan won't go above 70 mph. high rpms
First I need to ask is it a 4 speed or a 3 speed transmission. If it's a 4 speed when driving down the road pull it from drive to third gear. You shpuld hear the engine speed up if it does not then that means you have on 4th gear and you will have to take it to a transmission shop. If it's a 3 speed then just count the shift points if all 3 gears are present then drive down the road and see if the van goes into tcc. When you mean the rpms are high how high are they.
Jul 15, 2009 | 2000 Dodge Caravan
My 2000 Accent GL is reving into HIGH RPMs! 5 speed 1.5 L
check your anti freeze and watch your temp gauge.any check engine light on.
Nov 15, 2008 | 2000 Hyundai Accent
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
148 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
