SOURCE: 50 inch Sony vega tv
There is a defect in Sony TV's Models: KDF-60XBR950, KDF-70XBR950, KF-42WE610, KF-50WE610 and KF-60WE610. That will be covered by Sony before june 30 2008. Check Sony's web site. Here is the link http://esupport.sony.com/US/perl/news-item.pl?mdl=KF60WE610&news_id=237.
SOURCE: 50 inch samsung plasma that is 3 years old
not necessarily, sometimes the connectors that feed the screen get old and dirty
If you have some electronic skills, open the TV and clean the connectors around where you see the symptoms and you may have a good chance to get if fix by doing that...
good luck
SOURCE: My 50'' Samsung Plasma has dead screen after only 2 years
welcome to fixya!
without doing voltage checks, my best guess is this:
Plasma hpr5053 or hps5053 models will burn out a buffer board or both, there are two buffers and the Y board.
I usually change all 3 at once, but if on a budget you can try to remove one buffer and see if you get half picture (upper or lower)
this is something only a technician should attempt. the boards cost $200 each (buffers)
$300-$400 (Y board).
if you actually get half a picture the Y and one buffer are good, a bad buffer usually burns out the Y board. and in really bad cases the panel is bad also (not common, but possible)
For part#s , specific help you can post a model# , but again this is a repairmans job not something the average customer can fix.
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Testimonial: "thank you sounds greek to me and costly but I guess I have to do what I have to do-----have you ever heard of a video IC board?"
SOURCE: 3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
