Question about Nintendo Wii Console
Wii power source probably broken
I bought an US Wii which expects 120v. Back in my country we have 220v so I plugged the power source to a 220 to 110 converter. It worked fine for about 15 minutes, until we heard a loud POP and the Wii turned off.
The 220 to 110 converter seems broken now (it doesn't power other stuff). I tried plugging the Wii power source to a different 220-to-110 - the red POWER led in the console actually turned on for a second, then went off. Now it doesn't turn on, neither the led nor anything else.
Burned the power source? What can we do?
  • 51 Answers
Plug something else into the adapter to make sure it works, if it works you may have blown the Wii's fuse which will need repair.
Posted on Jul 28, 2009
Rainbow e2 type 12 120v , accidentally plugged into 220v, would barely power up, possibly controller board defective?
probably need both as the extra 100 volts would burn the board and the motor
it is never advisable to buy electric equipment from another country because of the voltage differences but even then the plugs are made different so that the cord will not plug directly into the power outlet.
Aug 12, 2015 | Rainbow Vacuums
I accidentally plug my Wii that I got from US from 120v to 220v. I got the converter but I mistakenly plug it to the wrong voltage:(. I heard the poop sound. Did I burn the power adapter or the wii it...
You have most likely cooked the Wii itself, To check connect the correct power adapter to the correct system and in the correct power source ( 120v or 220v ) if it works all good if not you know you cooked it. If you are unable to test in this manner have it checked by a qualified technician.
Jan 11, 2013 | Video Game Consoles & Games
I bought my wii in singapore. the wii says 120V, but here in sri lanka the voltage is 220. without reading this i plugged in the wii. the red light came but before i activated it, i heard a BOOM from the...
It is possible that your power supply fried but everything else is still ok. Something like this could happen during a lightning storm. If you know someone with a wii, try to use their ac adapter (with a 120V adapter). If this works, then you just need a new power supply which is much cheaper.
Sep 01, 2011 | Nintendo Wii Console
I am trying wire a motion Senior its has 3 wires coming out the back red white black
To connect a separate motion detector to a light fixture (and assuming the fixture uses incandescent or the newer twisted florescent light bulbs), the RED wire from the detector is attached to the black ("hot") wire from the fixture; the WHITE wire from the detector is attached to the white wire from the power source; the BLACK wire from the detector is attached to the black ("hot") wire from the power source. Sometimes the white and black wires from the power source are mixed up, reversed. So it is best to check to determine which wire is actually "hot" (shows voltage in a meter between the wire and the ground wire or the metal box the power wires come from). In general, a colored wire (often black) in the power source, if wired properly according to accepted custom, will be "hot" and 120v in US. The white wire in the power source is called the "neutral" and should be neutral with the ground wire and/or the metal box. If there is another colored wire in the power source (often red) and if it is not taped with some black tape (to indicate it is really a black wire), then it too may be a 120v. hot wire, but it may also be an 120v. hot wire that is 120v opposite the other 120v wire. That is, one 120v wire is 120v+ and the other is 120v- The difference in voltage between these 120v wires + and - is, hence, 220v. If you see multiple colored wires, it is also a good idea to check the voltage between them to know if you are dealing with a power source that entails 220v. In short, you want to know what you are doing, obviously for personal safety, but also to accomplish what you want... to properly connect the motion detector.
Dec 12, 2010 | Home Security
I have bought a wii in us. i brought it to india, bought a plug, and tried it but i think it got shocked help
In case you brought it from US and didn't use a manual stabilizer to bring down the voltage to 110 and plugged it in India in that case the power supply for the wii is blown and you would need to get it repaired because in India the voltage used is 220 V as compared to US and some other countries where the voltage is much less than 220V.
Oct 06, 2010 | Nintendo Video Game Consoles & Games
Will my Logitech X-230 speakers work in a country with 220-240 V power outlets or would i need an adapter to use them there? If i connect them directly to the 240 V outlet, will they run properly or would...
Check the back of your sub to check your voltage range. You will see something like this: 110V-120V or 110V-220V. If you see the later, you are ready to go. If you see 110-120V only, you will need a power converter to power your speakers as well as any other 110-120V equipment. But no matter what, if it is 110-120V DO NOT PLUG DIRECT TO 220V!! It will blow your speakers. (I lived in Germany for 11 years.)
Aug 12, 2009 | Logitech Z-2300 Computer Speakers
Changed power supply from 110v to 220v, now get 50.2 fuser error
The printer will have a 120v fuser, unkess that has been changed for a 220v fuser, it won't get up to temprature on 220v, hence the error message.
It needs a 220v fuser.
May 05, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
How to change tension from 120V to 220V
If you are sending a sewing machine which runs on 120volts to a region that has a 240volt power supply you will need to get a
power step down converter that will fit into the socket of the 220volt supply ,and will have a socket that will hold the plug of the 120volt supply going to your machine.
the converter must reduce the 240v down to 110v .
Aug 01, 2008 | Brother Sewing Machines
Nintendo Wii Console Logo
763 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
