May, Very limited info on this Crystal view, appears 30 day warranty, can not be returned to place of purchase, you are to call
1 866 815 4714 for returns.
Took a long time to find this, show your appreciation by pressing the helpful button and follow me on fixya for more tips and info.
I had the same problem with too fine a grind when I took mine completely apart to clean (including the lower burr). The solution I finally came around to was to further tighten the star-shaped screw which holds the lower burr assembly in place. I had originally just tightened it until the lower burr until the lower burr assembly started to turn with the screw, but that wasn't enough. So I held the assembly in place and tightened the screw further and I'm back to my previous grind coarseness/fineness.
The foggy images and lens was due to condensation caused by the camera's surfaces being cold in a humid/moist environment. Usually this happens and goes away without issue. If you believe issues are continuing, consider placing the camera completely in a bowl of uncooked rice. The rice should help eliminate the moisture in the camera.
Hope this helps.
what happened was it probally damaged the tan stripp (which is probally the reason it was unattached) then when you took it apart you may have damaged the battery ( those batteries are very easy to damage) good luck with your m.p.3.
photobucket has free webstorage for photos. then you can place a link here.
Definately sounds like a convergence problem. Have you checked your manual on setting it?
