SOURCE: init unable 4f
uninstall your printer software under control panel/add remove programs..then reinstall your software again make sure your printer is plug to your pc also...hope this helps..ITTech7574
SOURCE: brother mfc5860cn has error message print unable - 4F
Hi there
Please try this.
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: i get a message stating unable to init. 4F
Hi there
SOURCE: Unable to Init - Machine error 4f
ok please try this
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All files on my website are only there for a limited time
SOURCE: Brother MCF-5440 machine error 4F
ok
