Home Logo
l
larry lau Posted on Aug 23, 2017
I want to replace the leak cistern - Home
1 Related Answer
Bill Boyd
  • 53816 Answers
  • Posted on Aug 23, 2017
SOURCE: I want to take the cistern top cover to replace a leaking cistern.
most are just press in the sides to release the top
if it has a single button , undo the metal ring around the button and lift the top off
1helpful
How do I get to the Pozzi Ginori Cistern that has no no lid
Funny system. You usually have a large access panel of access from a tank room behind. Removal would be opposite of installation.
https://www.google.com/search?q=pozzi+ginori+cistern+installation+instructions
Apr 06, 2022 • Home
1helpful
Aug 23, 2017 • Home
I have a leak coming through my ceiling from the ensuite toilet above. It is an ideal standard wall hung with concealed cistern behind tiles. There is no obvious access panel. The tiled wall is flush.
The flush control panel normally comes off. You can then hopefully see inside. You won't be able to see much though as the cistern will be in the way...
Places to look for leaks are:
Soil pipe to pan
Cistern to flush pipe
Flush pipe to pan
Cistern overflow.
Apr 17, 2017 • Home
Cistern leaks into bowl
I assume you have a modern compact cistern that probably has an economy flush facility?
I have very little experience of these. There are two possibilities - firstly the water level could be too high due to a leaking inlet valve and the water leaking into the bowl is from the internal overflow.
A friend has recently had one of these fitted to economise on water but it soon developed a constant leak into the lavatory pan. I checked the water level which was ok and then she called out the guys that fitted it - twice! The first guy took it apart and could find nothing wrong so put it back again and when the leak had stopped went away. The next day the leak was worse and so another guy arrived and did the same but in an effort to justify his existence replaced one small fibre washer and one small O ring even though they appeared to be ok.
The leak stopped and to date has remained stopped. Clearly that type of cistern needs to be assembled very carefully with the sort of precision not typical of plumbers or plumbing.
Nov 07, 2016 • Home
I have a dual flush consort cistern N 81008, it keeps leaking into the pan after flushing .
You will need to replace the seal under the flush valve, need to dismantle cistern mechanism.
Oct 19, 2014 • Home
1helpful
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 • Home
Imperial toilet cistern parts
go to the website and read for instructions on replacing the float valve or the flapper or the float
Jul 11, 2013 • Home
I have three toilets and all have the same problem noisy and leaking back into bowl constantly
The flush unit has washers in the cistern that must be changed when the leak starts. you can do it yourself as the cistern must be checked to remove the float and the rubber seal must be taken out to be replaced by the same type / size.
1helpful
Low-level Cistern - leaking from syphon back nut.
Assuming the seal washer is inside the cistern and there are no cracks in the cistern itself you could apply a silicon sealant to the seal washer inside the cistern.
Apr 04, 2010 • Plumbing
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
