SOURCE: Emerson flat screen tv with red stripe
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
Try leaving the TV unplugged for 30 mins so the TV can reset itself.
If that doesn't work, most cases with the Emerson TV, the Inverter Transformer goes bad on the backlight Inverter Board. It's what powers the screen for your TV. If it can't power up the screen, it automatically shuts off. Basically, they call this "Protection Mode" with this happens.
You can get a replacement backlight inverter board at this web site link:
http://www.shopjimmy.com/catalogsearch/result/index/?q=ewl3706+inverter&p=1&stock=all
Just make sure the board number matches your board.
If it fixes the problem and you decide to throw your old board in the trash, I would like to keep the damaged board if possible. I want to do some research on the board to find out what really causes the transformers to go bad. Here's my e-mail [email protected]
SOURCE: Emerson LC320EM1 flat TV will not turn on. Green
try turning off the power saverv feature
software problem ?
