Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer will not spin...
The panel lights up but most of the time when I hit start nothing happens. Occasionally you can hear the motor strain for a few seconds and then nothing. I can not move the drum that contains the cloths either. Seems stuck. Anyone have any ideas?
    President:
  • 2,187 Answers
During this cases, you may need to open up the panel to gain access to the internals and check which parts are stuck. I am thinking that the belt may be loose or needs replacement you can check that as well while at it.
Here is a link on how to replace it. Belt
If inspections does not show that the belt has issues it could be the motor. If you have a tester, see if there is voltage running to it or check if there is resistance. If the resistance measured is infinity, even when turning the motor then it could be bad.
For pieces that are stuck, a physical inspection should show, Check for cracks or parts that are rubbing against each other.
Posted on Jul 28, 2009
Model FEQ1442ES0. I press the start button and all I hear is a click, nothing happens. What's wrong?
I appreciate your inquiry, Cody!
I see that your Frigidaire dryer is not operating after you hit the start button and it clicks. It is possible that your control panel or wiring harness could be causing this issue with your dryer. You may need to perform a reset on your dryer and you can do that by disconnecting power from your dryer for at least ten minutes. If this does not correct your issue I would seek assistance from a professional technician for a proper diagnosis and repair. I hope this information is helpful to you. -Matt
Jun 15, 2015 | Frigidaire Dryers
Dryer will not start. Electrical source is ok, light is on and your can hear timer running. When you hit start button you can only hear a click and nothing happens.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 01, 2011 | Whirlpool WED5300S Electric Dryer
I HIT THE START BUTTON AND YOU CAN HEAR IT CLICK BUT NOTHING HAPPENS.
take dryer apart and look for a reset(break belt switch) on the motor:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 25, 2010 | Whirlpool LEQ9858P Electric Dryer
WONT START CAN HEAR TIMER RUNNING DOOR BUTTON WORKS MAKES START BUTTON RESET CAN HEAR IT RESET BUT NOTHING HAPPENS WHEN I HIT THE START BUTTON
heatman101
Nov 14, 2010 | Dryers
DUET DRYER MODEL NO. GEW9200LW1. DRYER WON'T SPIN. CONTROL PANEL LIGHTS UP, TIMED DRYING SELECTED, HOLD START BUTTON DOWN AND NOTHING HAPPENS. ALL I HEAR IS A CLICKING NOISE AT LEFT REAR OF DRYER. IT...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Oct 11, 2010 | Whirlpool Dryers
GE Profile gas dryer, DPXB515, no heat and no drum spin
the humimg you hear is from the motor,check the blower wheel that is below the lint filter,if a sock or something gets sucked into the blower the motor can't spin,check the belt,if it is jamed the motor can't spin,if these things check good you have a bad motor
Nov 05, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Dryer will Not Spin
I opened the dryer panel and saw that one of the two belts that stabilize the drum had come off. It is a soft, sticky, rubbery substance and part of it and balled up so it was wedged between the drum and the dryer wall. I cut that portion off and it runs fine now.
Dec 07, 2008 | GE Profile Harmony DPGT750EC Electric...
Fridgadare gallery electric dryer
i need the model number on this one some of those galleries were double rotation some wernt now if you hit the start switch and hear an electric buzzing sound open the door hold the door switch with one hand and spin the tub real hard to the right with the other but be ready to jerk your hand back if the motor starts then change the motor or clean the centrifugal switch most of time have to chang the motor when you find out reply to me for detailed instructions on how to do it also the rear tub bearings are bad about going out and jamming the motor 6 years old is about the time so check the tub for rotation first and if you have to do the spin start test be sure to set the timer first ok
Jan 02, 2008 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
20 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
