Question about Alpine SWS-1223D Car Speaker
Hello i just recently bought alpine speakers for my eclipse 2003
Hello i just recently bought alpine speakers for my car and i installed the 6x9's in the back and then i got the front ones in and there connected to the subs and amp to my reciever. the back of my car sounds great but when i hear the front its faint and i figured there should be more louder sound in the front. any reason why there is not loud sound in the front aswell?
  • 97 Answers
Mostly because the subs in the back are probley using more amps than the ones in the front in the front should be used mostly for vocals and your bass in the trun so maybe trying to unhook the ones in the front from the sub and just leave then hooked up to the cd player where you can hear the vocals really good and leave your subs in the back hooked up to the amp
Posted on Jul 28, 2009
How do you remove 6x9 speaker cover i 2003 buick rendezvous
speaker covers are normally made with a lip that clips over the body of the speaker . Use something like a flat blade screw driver an lever the edge of the cover up and it should spring off. To replace put the trim/cover up on the speaker and hit it on with the heel of your hand.
Apr 09, 2014 | 2003 Buick Rendezvous
Alpine 6x9 speakers 90 watt rms.Are they compatable with a pioneer gm 3000 amp
the alpines will take every drop of power from that pioneer and smile... it will sound quite good,and if you ever want to you can actually put about 2x that much power to them 1 of those amps per 6x9 would rock
Apr 08, 2013 | Pioneer GM-3000T Car Audio Amplifier
Hello. I need help installing an Eclipse sound system in my Dodge Ram 1500 Quad cab. I went from a Kenwood HU with db Drive 6.5's and 5x7's to the Eclipse CD3200 HU and noticed an immediate improvement...
So you wanna run the subs off of the rear pre amp output rather than just the sub out correct? just get a splitter and run both the rear speakers and sub off of rear channel and front off of front channel. or run all four off of front and subs off rear output. this should give you the sound you want
Nov 04, 2010 | Car Audio & Video
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
Whats the best alpine 6x9? dds-r69g,sps-6939,spr or others
All of these work nice, remember the quality of the sound depends primarily on the source ( car stereo and/amp) and then the speakers, you need to know what Ohm and what watt is the minimum requirement for your sound system.
Feb 07, 2010 | Alpine DDS-R69G Car Speaker
I have 2 6x9 speakers up front 4 6 1/2 3-ways
Hello rjmiller4039,
Although amps with 5 channels are pretty rare, you can get one. Alpine, Boston Acoustics, Infinity, JL audio, MTX, and Polk all have 5-channels ranging in price from around $350 up to around $1,000. The Alpine PDX-5 will output 75X4 watts RMS for the front and rear stereo channels and 300 watts to the mono sub channel. It is priced at $599.99 at Crutchfield.
Hope this helps.
Sep 18, 2009 | Jl Audio 500/1 Car Audio Amplifier
Amplifier displays "CUR"
Hello anwbrown,
The "CUR" display means that the amp is drawing excessive current and the protection circuit is activating. Too low impedance or shorted speakers will cause the amp to draw excessive current.
The Alpine V12 is a Class D mono amp with only one set of speaker outputs. All versions, M301, M501, and M1001 are only stable to 2ohms. Assuming that all 6 of your connected subwoofers and speakers are 4ohm and they're all connected in parallel, the amp sees a .67 ohm load, far below it's rated impedance.
When brand new, the amp could probably operate at low to moderate volume levels without drawing excessive current. But as electronic components age, their tolerances change and they become less able to withstand excessive current or mismatched impedances.
I'd get a 4-channel amp and drive the 4" speakers off the front channels and the 6X9's off the rear channels. And just power the subs off the V12 making sure that they are connected to show a minimum load of 2ohms.
Hope this helps.
Jul 27, 2009 | Alpine MRV-F345 Car Audio Amplifier
How many speakers can u hook up to a cde-9872
yes the alpine can handle that depends on the wattage also might need a amp to go with all that
Sep 29, 2008 | Car Audio & Video
Finding the right speakers
you should install 2 8 or 10 inch wooffer on the back seat install mid range and tweeter its not very expensive it gonna sound great with that trunk you can do anything you whant 6x9 its sound like crap even the expensive one
Jan 17, 2008 | Competition Crystal COMP 10 - 10"...
Alpine SWS-1223D Car Speaker Logo
95 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
