Question about Canon FAX-JX200
Canon Fax JX200 - fax interupts phone calls
Our fax interupts phone calls and the only way to stop it is to switch it off so lots of trips running to the fax. It doesn't do it if the answer machine takes the call.
Canon Support suggest changing the Remote RX code or turning off remote RX.
Goto fax settings -> RX settings-> remote RX
Posted on Mar 24, 2008
The answering machine and the fax come on at the same time when someone is calling in - therefore they cannot leave a message due to all the squealing
I don't see a specific question being asked, but I assume you want to know how to be able to stop the answering machine and the fax machine from answering calls @ the same time.
The easiest solution would be to order another telephone line and use it for the fax machine.
The only other option would be to purchase a device that "listens" for the polling beep that fax machines make and, if it hears it, sends the call to the fax. If it doesn't hear it, the call is sent to the answering machine.
Here is an example:
http://www.usr.com/products/telephony/telephony-product.asp?sku=USR4000
Apr 09, 2011 | AT&T ATT1739 Digital Answering Machine
Sharp plain paper ink jet fax ux-b750
to stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
Oct 01, 2007 | Office Equipment & Supplies
How do i set up fax to automaticely receive faxes after several rings
For a phone line dedicated only to the fax machine, the process is as follows:
  1. Press Menu/Set, 0, 1.
  2. You will see the Fax Receive window
  3. Use UP and DOWN arrows to change the setting to FAX ONLY
  4. Press Menu/Set.
  5. Press STOP/EXIT
Your fax machine will now answer every incoming call.
If the fax machine is sharing the phone line with a telephone, repeat the above steps and change from FAX ONLY to FAX/TEL This option will allow you to share the line with a phone only, not an answering machine. Once in FAX/TEL mode, the fax machine will still grab every incoming FAX call, and give a special ring (slightly different than a regular telephone ring) when it's a regular incoming phone call signaling you to answer the phone. I hope this helps with your problem. Best of luck!
Greg
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
How do i stop the phone going through to the fax machine if you dont answer it after 5 rings, we have the same phone and fax number and if you dont get to the phone in time it will go to the fax. as we are...
Go to an electronics store (Radio Shack) and buy a spliter. They sell a spliter that recognizes the call as a fax or phone call and sends signal to proper line. When you hook up the unit you will have your line in, then the outputs will be marked one to the fax and one to your phone. Once you install this your problem will be solved. You only have to hook one at at the fax machine not at all phone jacks.
Oct 15, 2009 | HP OfficeJet 4255 All-In-One InkJet...
IT WILL RING BUT GOES TO ANSWERING MACHINE DOES NOT RECEIVE FAX
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
Canon image class MF4150 distinctive ring
How to Set the Receive Mode (MF4140/MF4150)
1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Brother inteeifax 775
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_775_EN_86.PDF
Aug 01, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Epson ACULASER CX11NF incoming fax problem
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
Feb 05, 2008 | Epson ACULASER CX11NF All-In-One Printer
Canon FAX-JX200 Logo
163 people viewed this question
old marine
old marine
