Question about Thermador SMW272 Electric Double Oven
Thermador SMW272 broiler works, oven bake temp resets to 100 after a few seconds and doesnt heat.
  • frankdobbela Jul 28, 2009
    thank you for the response - the broiler works and heats up - the lower element does not, for instance bake 450 bake, in a few seconds it turns to 100 on the display and stays there. If the lower element would be defective, is that something I could replace myself as I have pretty good diy skills? are parts available? any approximate cost?
    this forum has a problem ... it asks if I want to keep working with this person then does not let me submit my post to them.
    President:
  • 2,185 Answers
Find out which breaker it is on and shut off the breaker for a few minutes, then turn it back on.
Posted on Jul 28, 2009
    Top Expert:
  • Thermador Master
  • 76,630 Answers
Test the oven heater (lower) element, also does the broiler work? if it does this will confirm you need a new lower heating element.
Posted on Jul 27, 2009
Thermadore oven won't heat
Have you set the clock?
warmest regards
Richard The Repairman
Mar 27, 2014 | Thermador Ovens
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
Pre heat works on smw 272 yw but oven or broiler do not heat.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 ';';
Sep 22, 2011 | Thermador SMW272 Electric Double Oven
Oven will not heat up broiler works. its a thermador rdss oven
heatman101 ';
Mar 07, 2011 | Thermador SMW272 Electric Double Oven
Thermador smw272 oven does not heat. the op panel
Likely to be the Hi Limit Switch or the relay/power board.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | Thermador C302U Electric Double Oven
Bake element does not heat up but broiler does. Do
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 06, 2010 | Thermador SMW272 Electric Double Oven
Fan works, but Oven stays at 100 degrees. Tried
I had the same problem in December - I had to replace the circuit breaker and that solved the problem. My oven wouldn't go above 100 degrees in convection, bake and roast modes. Each of these modes are on a separate circuit so when one is bad, the others should work.
Jan 25, 2010 | Thermador C301U Electric Single Oven
The oven pre heats to desired temp and then loses
SOUNDS LIKE THE TERMOSTAT IS FAULTY REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
Nov 09, 2009 | Thermador SMW272 Electric Double Oven
Oven will not heat - Thermador SMW272 Electric Oven
since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
Dec 12, 2008 | Thermador SMW272 Electric Double Oven
Thermador SMW272 Electric Double Oven Logo
161 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
