As I toggle through the settings, hour, minute, year, etc. the time zone gets skipped so I can't set it.
SOURCE: Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
SOURCE: I live in Eastern Time Zone. My atomic clock shows map of
The "mode" button is there to change the function of the + & - buttons.
If you press the mode button several times you will cycle through the various setting features of the clock.
Look for the one that sets the time zone and use the + or - buttons to select your zone.
Some experimentation may be required!
SOURCE: setting time zone for atomic clock
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please..
SOURCE: I have a Westclox, Calander
It's most likely because of Daylight Saving Time. Your clock receives a signal through the air once a day from the actual atomic clock, much like a cell phone receives the time from your cell phone service provider, and it automatically resets itself to the exact time each time it receives this signal. Remember that the middle of the year (the second Sunday in March until the first Sunday in November in the US) is Daylight Saving Time for much of the United States. The clock has an option that allows you to set whether you are observing Daylight Saving Time or not. If this is set to "off", the time will be one hour behind until Daylight Saving Time ends (November 7th). Make sure this is set properly, and your problem will be solved.
SOURCE: Set time zone on centrios atomic clock
1. In the normal time mode, Press MODE key to enter the alarm time mode .
2 Press SET key to change the time zone, P is pacific, m is mountain c is central and e is eastern.
