RCA D52W20 52 in. Rear Projection HDTV-Ready Television
Problem for RCA D52W20 52 in. Rear Projection HDTV-Ready Television
RCA R52WH74 turns off 3 times
By kira-chan on Jul 27, 2009
I have an RCA R52WH74 rear projection tv. It turns on normally, then after a few minutes turns off, then the power light blinks three times. I poked around trying to figure out what's wrong, and similar problems had me check the capacitors CP150, CP120, and CP114. None of those capacitors look bad, but should I replace them anyway? I've already had the convergence problem and replaced a fuse and resoldered the flyback transformer.
Best Solution
posted on Jul 27, 2009
Very Helpful)
Shuttle83
Rank: Guru  RCA Expert
Rating: 85%, 990 votes
Hello Kira-chan,
You are going to have to take those capacitors out of the Tv and check them on a capacitance tester. Some digital multi-meters have them, but I would suggest using the LC102 by Sencore That way you can check the ESR, and the dielectric absorption of the capacitor. It is my suspicion that these caps are bad, but should be checked before replacing them.
In addition check the BLUE and RED CRTs for cracks around the neck oy the tube, BE CAREFUL.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
cyberdyers
Rank: Guru
Rating: 86%, 167 votes
good day sir, your problem may be overheating, check the switching regulator, it my be the IC or the transistor, if possible place thermal silicon grease between the heatsink of the regulator, make sure its screwed tight. hope this helps. thanks
Was this helpful?
Yes
No
Popular Solutions for RCA D52W20 52 in. Rear
Questions and Unsolved Problems for RCA D52W20 52 in. Rear
Do you recommend RCA D52W20 52 in. Rear Projection HDTV-Ready Television?
Answer
Answer
The format button will not change when in the CMP1 input but will change with all the other inputs.
Answer
RCA modelD52W20 Problems turning TV on when it is cold or for the first time after being off for an... (More)
Answer
everything on the tv is blurry and everything has like a red shadow around it.
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
