Question about LG KC550 Triband GSM 5MP Camera MP3 Phone Black
I have the screen problem the phone starts up but it is just a black screen any suggestions on fixing this issue ?
Screen blank on x836 turns on screen blacksout help thanks
Black Screen, Working Phone [Solved] - Phones - Cell Phone General ...
www.tomsguide.com/forum/id.../black-screen-working-phone.html
Dec 14, 2015 - 12 posts - ‎10 authors
I turn my phone off and then turn it back on, same result, black screen. I then tookout the battery and put it back in, same result. I took the battery ...
Why is my screen black but everything else works ... - iFixit
https://www.ifixit.com/.../Why+is+my+screen+black+but+everythin...
iFixitThe Samsung Galaxy S3 is a multi-touch, slate-format smartphone with ... I have a problem with my phone i dropped it and it works but all i see is a black screen ! ... was fine but then a couple of mins. later the screen started turning pink and when I .... i dropped my gs3, the screen cracked & the screen stays black, everythimg ...
Phone stuck on a black screen during or after a call? Here's ...
www.smartmobilephonesolutions.com/.../cell-phone-shows-a-black-scree...
Is your phone showing a black screen after finishing a conversation and not allowing ... causes and better yet some solutions to fix this issue on your cell phone. ... phone up to your ear, so that the phone will lock (turns on the black screen), ...
Jan 04, 2016 | Cell Phones
Black screen
Follow these suggestions
- Start the computer in safe mode and run System Restore
- Removing the graphics driver in safe mode might work for you Just remove it via Device manager.
- Check for registry issues
- Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Sep 15, 2013 | ASUS LCD Monitor
WHEN I TURN ON MY COMPUTER AND LOG IN TO ONE OF THE USERS THE SCREEN GOES BLACK WITH JUST THE MOUSE ICON APPEARING
I suggest you to go to safe mode and login in that user and check the start up items, if there is any unnecessary start up item remove it.
The screen is going black may be due to the recent virus attack or the system files might be corrupted. The re-installation of OS completely fixes your issue, If you do not want to reinstall the OS then you can check for the virus first and fix the issue.
You can go to safe mode by pressing F8 key before the OS boots up. Keep pressing F8 key once you start your pc. You will get the option safemode, safe mode with command prompt etc. select safe mode.
I suggest you to scan your pc for viruses
May 24, 2010 | Compaq Presario 700 470024-192 Notebook
Phone turns on (can feel it vibrate and hear messages coming in), however there is no screen - the screen is black.
Hi Dear,
This issue seem to be because of screen malfunction. This is a hardware issue. Hence, if it is under warranty, i would suggest you to take it to nearest service center for repair.
As it is hardware related, i will not suggest you to try to fix it your self. The problem might get intensified.
If you need more information on this, please write to us.
Have a nice day.
Nov 09, 2009 | Sony Ericsson Walkman W705 Cell Phone
Touch screen doesn't work and the screen itself blacks out sometimes
Mine has done exactly the same, and they wont fix it, they told me it was water damage!! but i have actually found, that if u turn it onto areoplane mode then turn it off and on then off areaoplace mode it works!! i really hope iv helped im so glad mine is ok for the next 10mins lol
Oct 25, 2008 | HTC G1
Orange LG EnV(VX9900) Cell phone problem
From description , it looks like a faulty display ribbon connector. The phone must be taken apart, and probably the part replaced to fix this.
Well that happens on Ebay, you pay less than RRP, but it is difficult to get guaranty cover.
My suggestion:
Ebay offers paypal cover up to $500 if you open a dispute with the seller within 45 days from purchase.
Go to Ebay, if you are still in time open a dispute immediately (even if they suggest contacting seller first), as time is running out.
After opening the dispute, contact the seller , explain the situation , and see if he want to give you refund, otherwise ask Ebay full refund through dispute resolution.
Oct 12, 2008 | LG enV VX9900 Cellular Phone
Picture will not display on my samsung sgh-u600
Probably the ribbon that connects screen to keypad
common fault on this phone
Aug 12, 2008 | Samsung SGH-U600
Vizio tv first screen had bluish discoloration and than few days later a pop and screen went black .ANY IDEA OR SUGGESTION all of the sudden started experiencing severe discoloration
This is called the pop of death! If you call vizio they will ask you if you heard a pop, this is a common issue and unless your under warrenty your looking at 916$ to fix it. (assuming you have no sound! If you do its 430$ plus tax for parts and repair. You can buy a used one on ebay for that price!
I have the parts numbers if you want them!
Call vizio if you have had this system for under a yr the will fix it free!
As for me my 50 and 42 inch had this issue and well I am out of warrenty.. I hate vizio lol!
May 24, 2008 | Vizio L32 32 in. LCD HDTV
LG KC550 Triband GSM 5MP Camera MP3 Phone Black Logo
142 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
