Question about Dishwashers
Dishwasher not getting water. GE nautilus
Dishwasher no getting water. GE nautilus
  • 6,784 Answers
HI. this is a water inlet valve issue. i recommend testing this device. it may be faulty.
To access the inlet valve remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first. If the solenoid is working properly, but water leaks through the valve even when the dishwasher is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
(((Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open before you proceed with the above test)))
Posted on Jul 28, 2009
My GE nautilus dishwasher does not start and not getting water supply.
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Dec 20, 2010 | GE Nautilus 24" Built-in Dishwasher
No water goes into dishwasher
Check the water inlet solenoid, it may be sticking/stuck Soak in a bit of WD40 or CRC. and, try a bit of percussive maintenance, IE: give it a "bit of a whack"
Feb 09, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
How do i drain my ge nautilus dishwaher
Pour hot water into the bottom and force the timer to drain cycle. Keep doing this until the suds are gone.
Aug 18, 2009 | Dishwashers
Dish washer has no water.
Check the faucet first, turn off the faucet, disconnect the dishwasher copper hose, re-open the faucet and check you faucet see if there is water come out, sometimes there is a small stone or sand block the faucet. Good luck, hope this can help, if not we check the others.
Jun 16, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher - NO water coming in at beginning
Normally,if water doesn't come in, cycle should not go on ! Add water by hand to tub and operate the dishwasher. Let us know with your results and we will see how could we assist you.
Aug 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
246 people viewed this question
Top Dishwashers Experts
