Question about Mitsubishi Televison & Video
I changed out the lamp and I am still getting the flashing orange lamp light. I pressed reset and it just comes right back to that flashing lamp light. What could the problem be?
  • 4,234 Answers
The first thing to check is the access door to the lamp. If this door is not completely closed, the lamp indicator will continue to flash. If that does not resolve the problem, update this and we'll try a few other possibilities.
Dan
Posted on Jul 27, 2009
After replacing the lamp in my sanyo projector, how do I get the lamp replace indicator off?
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 13, 2012 | Sanyo Office Equipment & Supplies
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
I have purchased 2 sony ex3 lcd projectors(one for spares,and one that needed a new lamp)I also have a new lamp!!But it wont work on either machines.All i get is flashing on/off light,then lamp cover...
you may have to reset the lamp hour meter to get it to work, put the projector on stanby and press the remote buttons, reset - back - forward - reset, (this is the code for a vpl hs20 projector it may be slighty different for your model)
Jan 14, 2011 | Sony VPL-EX3 LCD Projector
I have an lg projection tv model #RU-48SZ40. I needed to change the lamp, when I was done and turned the tv back on...the orange warning light was still lit. I then tried unplugging the tv, pulled the lamp...
What you need is to have the lamp timer reset. To do so, perform the following;
You will need two hands.
With the remote, press and hold down the "mute" button.
Simultaneously press and hold down the "enter" button on the front of the TV.
After about 5 seconds, a box will appear that shows the total number of hours on the lamp. To reset these hours, press the right arrow button on the remote. After doing so, another box will appear with a confirmation question and an icon for which button on the remote to press to reset the lamp hours.
Dec 15, 2010 | LG Televison & Video
I have a Panasonic pt-52lcx65-k. I thought the lamp was gone so i replaced it. Now the tv wont come on at all. Just a orange light flashing. I tried to reset it by holding the volume button and the pip...
Howdy,
Doble check your Lamp Installation, making sure that the Lamp Cover is properly secured. Reset TV by unplugging TV from the wall for 3-4 minutes then plug back in, then turn TV on.
To reset your Panasonic Lamp Time:
ø Press and hold these buttons for (at least) 5 seconds:
ø Volume Down button (on TV Panel).
ø AND ACTION Button (on remote).
As the remote gets older the ACTION button may not respond unless you press the button dead center and not at an angle.
Thanks for using FIXYA, BIG IRISH.
Dec 19, 2009 | Panasonic PT-52LCX65 44" HDTV
I have a zenith e44w46lcd tv, while watching it, it turned off and now will not turn back on again. Green light flashes for a bit then goes back to red. Also lamp light is on orange. Do I need to replace...
More then likely your lamp is faulty, you can replace this lamp urself, but on zenith models the lamp comes as a bulb only, you will have to change the lamp and use your original housing. Also lamp timer will have to be reset. The only reason you might need a repair man is to go into factory mode and reset lamp timer. But if you are mechnically incline you can swap the lamps yourself..
Thanks any questions email me at -
Delhielectronics@live.com
Sep 27, 2009 | Zenith E44W46LCD 44" Rear Projection...
Replaced lamp-orange lights still flash.....lame!
Yes, Turn On TV, press and hold Volume Down button on TV front and Split button on remote at same time for 6 seconds to reset lamp timer in TV.
Sep 19, 2009 | Panasonic PT-43LC14 43" Rear Projection...
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
HOW do you reset the timer>? the lights on front of the tv flash 3 gree then 2 orange. Says to replace lamp,which I did then reset timer...HOW?
press "menu" button, scroll down to "special features" and press "ok" button, scroll down to "reset lamp timer" and press "ok" button, you will notice the "no" change to "yes" and press "ok" button, you will notice "yes" change to "no", this will reset the lamp timer
Mar 20, 2009 | Vivitek V37655 56" DLP TV
Televison & Video Logo
196 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
