Question about Nintendo Wii Remote Controller
My second Wii controller does not connect. It used to work, but now no matter which reset I use (on the controller or on the console next to the SD card), nothing works. I have placed new batteries in the Wii controller, but that doesn't help. The controller's 4 blue lights flash, but nothing connects. The first controller works fine.
    Problem Solver:
  • 8 Answers
Have you tried one time syncing it? (By pressing home and then pressing reconnect controllers)
If you have make sure you're not trying to connect it in a single player game. If you do, the second controller will not connect.
Posted on Jul 29, 2009
    Problem Solver:
  • 9 Answers
Program it to the wii\
  • Killer K700 Jul 29, 2009
    program it to the wii\
Wii nintendo bought used how do i reset it
Method One: The Soft Reset The soft reset is the easiest way to reset the Wii, and the least intrusive. There are two ways to perform the soft reset, either using the Wii remote or the button on the console.
To reset the Wii using the Wii remote, begin by pressing the home button (the small button with a house on it). This will bring up a menu screen. Next, move the cursor to the button labeled "Reset" on the screen. Press the "A" button on the remote to select the reset option. This will reset the system.
If the Wii remote is not responding, users can also reset the Wii using the button on the main console. First, locate the button labeled "Reset"--it's on the front of the console, beneath the "Power" button. Press and hold the "Reset" button for two seconds, then release the button. This should reset the system. Users should remember that resetting the Wii will shut down any running programs immediately and destroy any unsaved data, so only reset the Wii if it is causing problems. However, resetting the Wii will not alter any information stored on SD cards.
Method Two: The Hard Reset If the soft reset doesn't fix the Wii, users can also perform what's known as a "hard reset." A hard reset involves disconnecting the Wii's power supply and must be done manually--there are no pre-programmed buttons on the Wii that will perform the hard reset.
To begin the hard reset, find the "Reset" button on the front of the console. Press it for two seconds, then release (this performs a soft reset on the device). Next, press and hold the "Power" button. Continue holding this button until the light in the button switches from green to red--this means that the Wii console has shut down. Now, unplug the AC power adapter cord from the wall outlet or surge protector as well as from the console itself. Allow the Wii to remain like this for five minutes.
Once five minutes have passed, plug the AC power adapter cord back into the console, then connect the other end of the cord to an AC outlet. Press the "Power" button to turn the Wii on. The system should now be running smoothly.
Method Three: Reset Factory Controls Sometimes, Wii users might want to return the system to its original, factory-shipped status and remove any personal data. Nintendo especially recommends doing this before selling or gifting a used Wii to someone else. To perform a factory reset, also known as formatting the system memory, go to the Wii menu and select the "Wii" button, then select "Wii settings." Click on the blue arrow on the right-hand side--this will bring users to a page called "Wii System Settings 3." Select the option labeled "Format Wii System Memory," entering the parental controls PIN if requested. Finally, select "Format" to complete the factory reset. This will remove all hard-drive data from the Wii, and such data cannot be recovered, so users should only perform a factory reset if they're sure they want to do so.
Jan 30, 2017 | Nintendo Video Game Consoles & Games
Tip
How to setup your Wii Controller.
To setup your Wii Controllers. Open the back of your Wiimote and insert the two AA batteries as indicated in the battery panel. Leave the cover off after you've inserted the batteries.
Turn on your Wii from the front of the console. Allow the Wii to cycle to the main menu.
Open the front door on the front of the console to reveal the SD card input and the "Sync" button.
Press the "Sync" button on your Wiimote, located just underneath the batteries. When it is in Sync mode the LED light will flash.
Press the "Sync" button on your Wii console to connect the signals and allow the controller and console to sync. This may take a few seconds, so be patient while it continues to connect.
Watch to see if the LED has stopped blinking. Once it has, your Wiimote is now connected to your Wii. Put the battery cover back on.
Use One-Time Synchronization to change the way the Wiimotes are synced to the console. You can do this by pressing the "Home" button on your controller and choosing "Reconnect." This is useful when you wish to change the player/controller layout without passing different Wiimotes around and losing track of which is which. One-time mode is reset to Standard once the Wii is restarted.
on Feb 15, 2010 | Video Game Consoles & Games
My remotes were synced to another wii how do I re-sync them?
Step by step instructions on how to sync the Wii Remote or Wii Remote Plus to the Wii console using Standard Mode.
Note:
Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
What to Do:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. If you are using a Wii mini, the sync button is located left hand side next to the battery compartment. The sync button is a darker shade of red than the console.
  3. Remove the battery cover on the back of the Wii Remote to be synced.
    • Some models of the Wii Remote include a hole in the battery cover and a tool on the wrist strap to push the SYNC Button with. With this model, the battery cover does not need to be removed to access the SYNC button.
  4. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED on the front of the Wii Remote will blink. While the lights are still blinking, quickly press and release the red SYNC button on the Wii console.
  5. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  6. This sync procedure must be followed for each additional Wii Remote added to the system.
May 19, 2014 | Nintendo Wii Console
My Wii remotes no longer communicates with the Wii. Yes the batteries are functional. We had a friend over yesterday who like to push buttons. It hasn't worked since.
  • 1 Open the back of your Wiimote and insert the two AA batteries as indicated in the battery panel. Leave the cover off after you've inserted the batteries.
  • 2 Turn on your Wii from the front of the console. Allow the Wii to cycle to the main menu.
  • 3 Open the front door on the front of the console to reveal the SD card input and the "Sync" button.
  • 4 Press the "Sync" button on your Wiimote, located just underneath the batteries. When it is in Sync mode the LED light will flash.
  • 5 Press the "Sync" button on your Wii console to connect the signals and allow the controller and console to sync. This may take a few seconds, so be patient while it continues to connect.
  • 6 Watch to see if the LED has stopped blinking. Once it has, your Wiimote is now connected to your Wii. Put the battery cover back on.
  • 7 Use One-Time Synchronization to change the way the Wiimotes are synced to the console. You can do this by pressing the "Home" button on your controller and choosing "Reconnect." This is useful when you wish to change the player/controller layout without passing different Wiimotes around and losing track of which is which. One-time mode is reset to Standard once the Wii is restarted.
  • JUST FOR REFRENCE
    My source is
    Read more: How to Connect a Wii Controller ' eHow.com http://www.ehow.com/how_2102965_connect-wii-controller.html#ixzz18iR4vpMQ
    Dec 21, 2010 | Nintendo Wii Console
    The remotes flash then switch off, i have synced them again but still wont work.
    start with the basics FRESH BATTERIES:
    1) Fresh batteries should be in each.
    2) Turn on the Wii with Player 1's remote or the button on the console.
    3) Open your SD Card cover and press Sync. Very shortly afterward, press the red button on your P1 Remote (in the battery cover). Lights will blink and then will be showing a light in the first square, denoting the connection is complete and it's P1.
    4) Do the same as Step 3 for the P2 remote. For the P2 remote, after the blinking, then the second square will be lit, meaning it's P2.
    That is the Standard Connection. It is tied to the Wii until it's re-done.
    After you attempt to synch them (pressing the red synch button on the wii, followed by the red synch button underneith the battery cover of the wiimote), make sure the wii is turned on and press the buttons 1 and 2 on the wiimote at the same time to have it search for recognized bluetooth devices (ie. your wii).
    _________________________________________________
    found this article too.
    this should help you.. leave a testimonial if I helped.
    The first thing I did while the Wii was turned on was that I tried to sync the Wii Remote by pressing the "1" + "2" buttons at the same time. The lights at the bottom of the controller flashed for about 30 seconds, but never received the signal from the Wii. Bummer.
    The next step I followed was to hit the sync button on the Wii Remote (Wiimote). Then immediately opened the cover for the opening where the SD Flash card goes and pressed the sync button on the Wii. 30 seconds of flashing, and no result. Double bummer.
    Finally, after some Google searching, I found a couple of message boards where people had to press the Sync button on the Wii (not the Wii Remote) for 15 seconds to reset it. I performed this step and then pressed sync on the Wii Remote. The 2nd controller synced up almost immediately. What a relief!
    Apparently the problem lies in the fact that the Bluetooth technology being used has to be manually synced in order for it to connect to the Wii. It does not make much sense at all. You would think they could be pre-authorized in order to minimize time and ease of use. In addition, you really have to be careful that your other controllers are turned on while syncing or else the controller that you are trying to put on channel 3 might end up on channel 2! This happened to me on one occasion.
    Good luck with getting your Wiimotes in sync with your Wii. Hopefully this helped!
    If this helped you out, please let me know with a comment below!
    Apr 10, 2010 | Nintendo Wii Console
    The wii remotes will not hook up to our game console how can i connect it?
    Feb 15, 2010 | Nintendo Wii Console
    Lost first player remote for wii have second remote but it won't connect. I pushed the reset on the remote,is there another button i am missing???? thanks
    What you'll want to do is, open the little panel in the front of the WII, it'll reveal an input area for an SD card and a red button, push that button, then open the back up of your controller, where the battery's are, and push the red reset. That should connect the two, you might have to do this a few times if it doesn't work the first time. Hope this helps :)
    Oct 19, 2009 | Nintendo Wii Console
    Wii will not power up. worked one day not the next
    Have you tried resetting the AC adapter? If not, then try doing this:
    1. Unplug/remove all accessories from the system (including game discs, SD Cards, memory cards, Nintendo GameCube controllers, hookup cables, the AC Adapter, and Sensor Bar) from the outlet and Wii.
    2. Let the system rest for about 90 seconds. While you're waiting, check to see that controller cords, AC Adapter, and Stereo AV cables/Component Video cables are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
    3. After the 90 seconds, Plug the AC Adapter into the system and directly into a wall outlet, not a surge protector or power strip. Check to see if the power light on the Power button comes on.
    Jun 29, 2009 | Nintendo Wii Console
    Connect wii my controller
    1 Open the back of your Wiimote and insert the two AA batteries as indicated in the battery panel. Leave the cover off after you've inserted the batteries. Step2 Turn on your Wii from the front of the console. Allow the Wii to cycle to the main menu. Step3 Open the front door on the front of the console to reveal the SD card input and the "Sync" button. Step4 Press the "Sync" button on your Wiimote, located just underneath the batteries. When it is in Sync mode the LED light will flash. Step5 Press the "Sync" button on your Wii console to connect the signals and allow the controller and console to sync. This may take a few seconds, so be patient while it continues to connect. Step6 Watch to see if the LED has stopped blinking. Once it has, your Wiimote is now connected to your Wii. Put the battery cover back on. Step7 Use One-Time Synchronization to change the way the Wiimotes are synced to the console. You can do this by pressing the "Home" button on your controller and choosing "Reconnect." This is useful when you wish to change the player/controller layout without passing different Wiimotes around and losing track of which is which. One-time mode is reset to Standard once the Wii is restarted.
    Jul 22, 2008 | Video Game Consoles & Games
    Installation
    You just need to reconnect it:
    When you have turned your wii on press the red sync button next to the SD card slot then press the red sync button on remote(s) under the battery cover. It/they should then be connected. You can then change which one is no.1 or 2 etc. by pressing the home button and going into remote connection and clicking on reconnect.Then press A on your Wii remotes on the order in which you want then (1 first, 2 second etc)
    Hope this helps
    Jun 17, 2008 | Nintendo Wii Console
    Nintendo Wii Remote Controller Logo
    2,100 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
