Question about Nokia 3230 Cellular Phone
No light on the display screen
This is a strange problem. Since today evening when i am using the
Nokia 3230 phone, there is no light on the display screen. However, there is light on the keypad. And its not only me, 2 of my friends using Nokia 3230 have got the same issue. Please help me with this problem.
  • 45 Answers
Re: No light on the display screen
yor phone's UI BOARD get faulty you should replace it
Posted on Nov 26, 2007
0 characters
3 Points
NOKIA 3230 - 'Switch on' problem Hi, My nokia 3230 mobile got switched off on its own and I am unable to switch it on since few days. Even the logo "Nokia" is not appearing on switching the power switch....
Hi ,Try to charge your mobile with another same model battery, switch it on.. and keep it swiching on for five mins,, and try with your battery .. its really works.. this is all because your battery charge limit is gone under minimum
May 30, 2009 | Nokia 3230 Cellular Phone
Nokia 3230 screen goes blank after a few minutes of turning on.
hello !
replace the LCD theres a posibilty of it being foulty , the IC on the lcd is damaged and please check the lcd socket on the MB .
Thank you
May 28, 2009 | Nokia 3230 Cellular Phone
My phone nokia 3230, not started properly, terminate starting
first switch off ur mobile then press call key+asterik+3 and switch on ur mobile press these keys untill formatting is displayed
Mar 29, 2009 | Nokia 3230 Cellular Phone
NOKIA 3230 phone rejects SIM card after it was fallen in water
Take the sim card out and wipe the contacts clean for both the sim card and the phone. You can use a clean business card to clean the phone side.
Jan 24, 2009 | Nokia 3230 Cellular Phone
Nokia 3230 started then open menu then select setting option then select phone then select general then select orignal phone setting then display a code box that is i forgot help me
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
This is your solution! Please vote!
Oct 22, 2008 | Nokia 3230 Cellular Phone
No display on nikia 3230
wether u getting incoming r outgoing if u get it wil b hardware fault if it not it wil b software fault
Oct 07, 2008 | Nokia 3230 Cellular Phone
No light on display screen
UI board gets faulty please replace it contact a repair centre
Nov 22, 2007 | Nokia 3230 Cellular Phone
Nokia 3230 Cellular Phone Logo
231 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
