Question about Microsoft Windows XP Professional SP2 Full Version OEM for PC (E8504026)
Pc problem windows does not start up
I can only access thru safe mode. on start up after windows logo appears screen goes black same thing happens if i choose to go to last working settings cannot do a system restore from safe mode says it was disabled searched online told it might be a video card problem tried 2 different video cards same problem on those do not have disk to do a windows repair becasue it is in safe mode cannot do a windows update
  • luis815tx Jul 29, 2009
    i do not have the option for a windows repair only a clean install.
    Brigadier General:
  • 4,090 Answers
If you can get video in start mode its not the video card ! It;s more likel;y a sytem file that is corrupted.If you have the skill and the original disk youn could try a system repair you will need to access the Bios and set up the boot sequence so thast the windowsa disk CD is the boot disk. set ATAPI in Bios to be the boot source and then let windows find its slow track to install, repair etc. If repaoir fails you may only be left with the option of deleting the partition the create a new one and allow windows top reinstall.
Before all that happens save any documents and pics or other data that you want to keep while in safe mode.
Posted on Jul 27, 2009
    Genius:
  • 1,043 Answers
When you do a repair install, you start your computer from the Widows CD. After the initial items finish loading, the system will ask you if you want to try and repair the install that already exists on your hard drive, or if you want to do a new install. At that point you would choose the repair install. Depending on what is causing the original problem, the Windows CD may not see your original installation. If that is the case, then you must decide if you want to do a fresh install, or attempt to fix your original install in some other manner. One thing to consider; if Windows cannot see your original install, then you have a serious issue. Depending on how important the data on your drive is, you may be looking at having to spend a lot of money to have a forensic hardware specialist attempt to repair the drive. You may also want to have your local computer shop take a look at your system. Most shops have access to some very good tools that you would probably find to expensive to use once.
My Acer aspire turns on shows windows logo then goes to black screen, what can I do?
Depending on your version of windows, I would trying starting in safe mode to see if the computer does boot. If it does, then you want to restart again, go to advanced boot options and select "start windows with last known good configuration." Access advanced boot options following the steps at this link. Need to Start Windows 7 in Safe Mode Here How
Jul 18, 2015 | Acer Computers & Internet
Start up will not run
Try getting in to Safe mode: F8 before Windows starts to fully load.
Start your computer in safe mode Windows Help
May 20, 2015 | Gateway Ne56r34u 15.6inch Laptop Black
Window 7 every 20 minutes hang
Many things could be causing this, the first thing I would do is boot into safe mode and see if the issue continues.
Safe Mode
Just before the Windows 7 splash screen (black with windows logo) appears, press the F8 key to enterAdvanced Boot Options.
You should now see the Advanced Boot Options screen. If not, you may have missed the short window of opportunity to press F8 in the previous step and Windows 7 is probably now continuing to boot normally assuming it's able to. If this is the case, just restart your computer and try pressing F8 again.
Here you are presented with three variations of Windows 7 Safe Mode you may enter:
  • Safe Mode - This is the default option and is usually the best choice. This mode will load only the absolute minimum processes necessary to start Windows 7.
Mar 15, 2011 | Toshiba Satellite L305D-S5935 15.4-Inch...
My dell inspiron cannot boot. On startup dell logo screen appears with only f2 and f12 options then my screen goes black with a flashing dash in top left corner. I cant access safe mode, i cant do anything...
The Operating System in your hard disk gone corrupt, you need new installation of Operating System using boot from CD/DVD.
P.S. Formating of Harddisk is recommended, because it seems the act of virus infection
Good Luck
DO rate if helps
Dec 02, 2010 | Dell Inspiron 1501 Notebook
Computer boots up shows windows xp and start up then monitor goes black if i switch it of and on it comes on for a couple of seconds and displays desktop then goes black have tried another monitor same...
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 14, 2010 | Computers & Internet
Won't start completely
You have a virus I hope you have your data backed up. Reformat your hard drive(I assume you have a boot disk)
Dec 25, 2008 | Microsoft Windows XP Professional for PC
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
Black screen
It seems your Operating system has corrupted, Its best to use Windows Installation CD to perform Recovery Installation. You can Use the DELL Disk. Before proceed Make sure you have your backup. If you need some advanced access to files you can use UBCD.
Good Luck
Jun 19, 2008 | Dell InspironTM 1501 Notebook
No screen on my toshiba 9100
Hi Alex
I suggest going to Safe Mode and see what happens. You do this by tapping F8 right after the Toshiba splash screen. There should be an Advanced Windows Options menu. Choose Safe mode and wait, if everything appears ok then its probably a driver problem, a reinstallation of those should do the trick, if not, then we might be looking at something a little more critical. Let me know what happens.
Cheers;
Veedubber
Nov 26, 2007 | Compaq Presario M2000 Notebook
Microsoft Windows XP Professional SP2 Full Version OEM for PC (E8504026) Logo
94 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
