SOURCE: Runs in reverse, but no on auto.
check and see if there is a jam of paper inside the unit or around the sensors
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
SOURCE: Shredded a few sheets of
Hi, make sure the cutters are not jammed with paper. To reset turn the unit to reverse for 2 seconds then auto then off. Allow to cool for 25 minutes then retry. Also make sure the base is locked in properly. Hope this helps, regards Phil.
SOURCE: My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
